2 day old tractor front tire flat.
   / 2 day old tractor front tire flat.
Wrestling a tire on/off a rim would make a good video...with sound of course.:laughing: At 145 pounds, and 77 years the tire nearly wins when I try it. More than two irons is helpful, I've noticed.
I have three tire irons.
   / 2 day old tractor front tire flat. #12
When I roll a tire off the rim I just take it to the tire outfit and have them put a tube in it. Both tires done now, no more problems. The problem with tubeless is that as soon as the bead breaks the tire is flat. With a tube in it, the tire will ride through a momentary side jolt without losing air, and the bead re-seats automatically.
   / 2 day old tractor front tire flat. #13
:thumbsup:
:thumbsup: Good point. I don't use the sealants in my tires but plan on putting inner tubes in when the time comes.
   / 2 day old tractor front tire flat. #14
On small tires I take one of those ratchet strap clamp things put it around the tire and ratchet it down until the beads are pressed againest the rim and fill er up. Works with those annoying small tires on carts, generators etc. but never tried it on tractor tires. They make them pretty big though and they cost alot less than 400.00 dollars like the tank thing.
   / 2 day old tractor front tire flat. #15
Many threads here about flat tires.
More power to the OP for fixing a flat.
I've had the same rear tire go flat twice. Luckily I was able to slime it and (do to hot weather softening the rubber) it popped back in after I got it off the ground (backhoe stabilizers are real handy for rear flats) both times. If it had been winter it would have been a bear.
   / 2 day old tractor front tire flat. #16
I don't think I have any tires that old.
   / 2 day old tractor front tire flat. #17
I bought a gallon of some Slickmabob at PepBoys years ago, makes unbelievable difference while mounting tires. I also use three irons, from HF or TSC not sure now.
   / 2 day old tractor front tire flat. #18
+1 on this
On small mower front tires I have even took my belt off and cinched it around the tire and put the air to it to get the bead seated. I have always used Berrymans "tire snot" It has dacron fibers in the "slime" and will plug quite big holes, like black locust thorn holes at least for a while. sometimes they blow out with spectacular displays of liquid shooting out of the hole.. at least you can find it and maybe get a real rubber plug put in for the big ones.
James K0UA
   / 2 day old tractor front tire flat. #19
Hey, guys, here is a tip for seating a tire bead.
remove the valve from the valve stem.
Take the end of your compressor air hose with nothing in the female end and push it onto the valve stem.
The valve stem pushes the air valve in the hose female fitting in and a very large volume of air rushes into the valve stem quickly seating the tire bead.
Sometimes setting the wheel on a pail or 30 gallon drum allows getting the bottom tire bead sitting on the rim. This as well as ussing a ratchet strap around the circumfrence of the tire will help the seating process too.
I use the air chuck / valve stem method all the time. it works like a charm.
Safety note, make sure to remove the air chuck from the valve stem immediately after the bead seats. Reinstall the valve and air up the tire as you would normally, paying attention to appropriate tire pressure.
   / 2 day old tractor front tire flat. #20
:DWell, you are getting pretty close on some of those you list. BTW, there is some good stuff for the DIY grunts in this thread.
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
2000 WINNEBAGO FORD F550 RV (A50854)
2000 WINNEBAGO...
2014 Chevrolet Equinox (A50324)
2014 Chevrolet...
2012 LINDE H80D FORKLIFT (A50854)
2012 LINDE H80D...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
