Tires Need new front tires 1985 yanmar ym2000d
/ Need new front tires 1985 yanmar ym2000d #1
jackpod
today one of my front tires sidewall decided it was done. I really need all 4 as they are all sun cracked, but for now I just want to replace the fronts. Anyone have a recommendation where I can get a pair of fronts, being this tractor is 4wd, it has the "V" tread just like the back. I am in Northern Arizona but am open to online purchase
Thanks!
/ Need new front tires 1985 yanmar ym2000d #2
Thanks!
Are you sure of the year on your tractor? Thought the 2000D was a 77 - 78 model. There may be many sources for tires but try Hoye. They have nice website with illustrations and tires are available. Good luck.
No I am not sure of the year, not even sure it is a "D" I was told it was a 1985. Is there any way to determine the year? It is a 2 cyl diesel with a Koyker bucket
I'll check Hoye
well according to Hoye it is a "D" as it is 4wd. I thought I had read the "D" stands for 4wd.and you are correct, it is somewhere between 1975 - 79. That's ok with me the hour meter shows 308 hours
/ Need new front tires 1985 yanmar ym2000d #5
I wouldn't trust the hour meter either. It could be 1300 or 2300 or have been set back. Was it straight from Japan or do you happen to have a VN refurb???
I dont know the history. About 1.5 years ago I stopped in the local tractor dealer (now out of business) We had a bad snow storm and I live on 2.5 acres with a 300 ft driveway. Of course the guy tried to sell me some $17k Kioti and when I told him that was too much money and walking out the door, he said wait, that a customer of his had just bought a new tractor and was trading in a "grey market tractor" I went and looked at it and drove it home for $5k. The only problem I have had is the roll pin on the gear shift lever broke. It was an easy fix. I've put about 90 hours on it.
I found some pictures on google, it is definately a 1975-1977...
good info to know, thanks for making me investigate
/ Need new front tires 1985 yanmar ym2000d #8
If it helps ... the US version of that tractor was YM240D, sold here for a few years after the YM2000 series ended in Japan. I think the last year here was 1981, maybe 1982.
You might like to see Yanmar's US sales brochures for this model. Just click on my sig line below this post. The brochure lists tire size and the other specifications.
/ Need new front tires 1985 yanmar ym2000d #9
Any Firestone Ag., or rural tire store should have your tires, although you will probably have to switch to R1 instead of "rice" tires.
/ Need new front tires 1985 yanmar ym2000d #10
I can supply you with tires.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2016 Isuzu NPR-HD Box Truck (A60352)
2016 Isuzu NPR-HD...
2026 tilt trailer (A56859)
2026 tilt trailer...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2022 Case SV280 (A60462)
2022 Case SV280...
