Pole Barn Loft Framing
/ Pole Barn Loft Framing
Eddie - There will be nothing hanging from the trusses? There will be a 2x12 header carrying floor joists, the 2x12 will be hanging on every post on 12' centers, the posts and headers will be carrying all the load, not the trusses? Not sure where that came from?
/ Pole Barn Loft Framing #12
If your ledger board (the 2x12) is supported on the posts (12 feet apart), I'd be concerned that there will be bending in your ledger board.
Usually, when using a ledger board, the supports are at closer intervals.
When you see 2x10s or 2x12s used as a girder, they're doubled or tripled, something that would be rather cumbersome in the setup you've described.
I'd certainly consider placing diagonal supports from the ledger to the bases of the posts, basically dividing the 12 foot span by three.
I guess you could do that later if your loft turns out to be springier than you like.
I'll join the others in recommending the use of rafters instead of the scissor trusses.
/ Pole Barn Loft Framing #13
Just some pictures to think about.
/ Pole Barn Loft Framing #14
Attic trusses were $4k more than scissor trusses. I would use rafters but trusses GREATLY simplify the building process and make it much fast IMHO.
I think you may have missed my point.
Use the scissor trusses. But put some, lets say 5 attic trusses on one end. That gives you a loft, without busting the budget.
You could also use a combination of scissor and storage trusses, which are a lot cheaper.
I say, rob a bank if you have to, but find the $4k, and get the full length attic. I have that in mine, and everyone I know, wishes they had done it. :thumbsup:
Also been thinking perhaps a monitor style barn would be easier to incorporate into, maybe not.
Does anyone know of a good source for pole barn building plans that would take some of this guess work out?
These plans look nice but I know nothing about the company and dont know if they are engineered or not.
Monitor Style
Gable Style
/ Pole Barn Loft Framing #16
If I am reading your post correctally, You are planning on a 2x12 ledger board around the perimeter of the building on the long walls (48' walls) and plan on spanning the 36' length with floor joists???
If you do this, regular dimensional lumber will NOT span the 36' without posts/support underneath. Which means you won't have an open 36 x 48 area underneath. You will have to have posts/beams on the under side. Even engineered lumber/floor trusses are going to have a hard time clear-spanning the 36' length and would be really expensive. Even a 2x12 SYP with only a 30PSF live load spaced 12" appart would only be able to span 20'.
If it were me, and you want to maintain an open lower level, get yourself 2 36' I-beams and place them 16' appart. Then use 2x10's or 2x12's between them @ 16" centers. See attached.
I have also attached a few pics of how I did a 30x30 loft in my 30x50 barn just to give you some ideas. I used scissor trusses as well but they were built by me.
I guess I'm not making myself clear.
There will be four rows of posts running 48' so basically I will run 4 2x12x48 headers there will be floor joists between them spanning 12' only. The inside of the building will have posts every 12'.
/ Pole Barn Loft Framing #18
I think some of use were getting confused and thought you wanted to run 36' without supports beside the side walls. With 12' spans you should be fine. How tall do plan on the side walls being? Head room in the loft would seem to be where you will have a problem.
MarkV
/ Pole Barn Loft Framing #19
OK, I missed the part about the two rows of posts down the middle of the building.
OOOPS.
Eddie
1981 FRUEHAUF CRUDE OIL TRAILER (A60736)
1981 FRUEHAUF...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 HINO SA (A58214)
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2007 50FT T/A 3 CAR HAULER TRAILER (A59906)
2007 50FT T/A 3...
BOBCAT T190 (A60736)
