Tractor pictures
/ Tractor pictures #222
/ Tractor pictures #223
Just found this site and wanted to introduce myself and show off my NTM tractor. It's a Ford 1510 that I got this spring and it came with a 5' finish mower and a 5' bushhog. My wife, my 12 yr. old son and I are all enjoying using it to cut our 3.2 acres. I got it because half of my property is a field with heavy grass, especially after it rains and I can't get out there to cut it until the low part dries out. By then it can be 18"-24" high in some places. These pics were taken just as we got it home before taking it off the trailer.
Hey Mike, that looks like a Diamond C Road Clipper utility trailer that you're toting that Ford tractor on. Am I right? If yes, what do I win???:D
/ Tractor pictures #224
One of my trail cameras snapped a photo of me mowing. The other is a picture of my old Ford 3230.
/ Tractor pictures #225
The latest.
/ Tractor pictures #228
I'm sure there's a story behind that hat Roy. Maybe we should do a thread on hats?
Rob
/ Tractor pictures #232
My old compact, a 1947 Ford 2N (mostly), and my new compact, a Kioti CK35 HST.
/ Tractor pictures #234
I'm only 16 hours in, but so far I'm really happy with it. I wanted a DK40SE HST but it was a bit beyond my budget. My dealer said the CK35 was more than enough for my 10 acres, and he's probably right -- of course, I think he said that because the CK35 was right there and all ready to go, heh. It's been a big hit with the neighborhood and the wife is digging it, so you can say I'm pretty satisfied.
/ Tractor pictures #237
Could explain for the forum to know the details.??
Well its a long story but here it goes. The main idea was that the loader was crap and the hydraulics were weak. Before i got my 4320 i had a Kioti CK30 with a KL130 FEL. According to Kioti the loader is rated to 1,200lbs of lift capacity. Well a friends house was being built. They had rocks being brought in to build a brick wall. They also had a Deere 2320 with a 200cx FEL. The lift capacity on that was 899lbs. The rocks came on pallets and the truck that dropped them off left them right in front of the house. They said the they needed help moving them and that they didn't want to push their 2320 with no ballast and unloaded tires to hard. According to the company they bought the rocks from the the pallets weighted 1,012lbs. I figured my kioti would lift it no problem with a box blade on the rear. So the day before my dad and i jump in the truck to go borrow a pair of pallet forks from a friend with a kubota B2910. We loaded them up and drove to the people with the rocks house. I was going to move the pallets up a slippery hill (it rained the day before). That scared me a little, but with 4WD engaged the ROPS up and my seatbelt on i would be fine. I unload the tractor hook up the forks and get ready to lift the first pallet out of three. I am running at about 1,700RPM and when i go to curl the forks the tractor stalls. I rev the tractor up fully and try again. The curls and lifts them 3ft off the ground, but you could tell the was alot of strain on the tractor. I start to roll up the wet hill and all **** brakes loose. The pallets uncurled and dropped the load everywhere:mad::mad: I got off the assess the damage and and none of rocks are broken. I was really mad. I asked the folks if i could barrow the 2320 to finish the job. They were all for it after what had happened. I was even more scared on this tractor. I unhooked the forks from the Kioti and but it on the deere, and i also put the box blade on it. It lifted it with no problem. I was shocked :shocked: Why could a tractor the was 7hp less and a loader that rated to almost 300lbs less lift it and mine couldn't. The next day it went to the kioti dealer. It needed new hydralic arms for the loader bucket at less then 300 hours. I was furious :mur: A week later my dad took the tractor to work to lift 1,000 concrete footings off a car trailer. It would even get them off the ground. I thought to myself it was time for a new tractor. Then after selling the kioti a summer and winter of tractor work, i had enough to buy a JD4320. And here i am.
/ Tractor pictures #238
More pics, this time a pair belonging to my FIL -- a non-running Ford 9N "project" and a Zennoh ZL 2402 gray-market import which he acquired by trading a wrist watch for it.
/ Tractor pictures #239
Great explanation of the fail.
I can understand your frustration.
Welcome to Green.!!:thumbsup:
/ Tractor pictures #240
Chris are those grab bars on the 9n in that picture from an office chair?:laughing:
2007 Dodge Ram 1500 Pickup Truck (A61573)
2007 Dodge Ram...
12,000 GAL FLAT BOTTOM ALUMINUM STORAGE TANK (A63291)
12,000 GAL FLAT...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2016 FORD EXPLORER SUV (A64280)
2016 FORD EXPLORER...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
