Kubota's sizing explained...
/ Kubota's sizing explained... #1
Big Wave D
Kubota L35, Kubota B6200E
I'm sure that this questions has been asked before, so please just point me in the right direction for the previous post(s).
My question is can someone please explain what Kubota's model numbering systems 'works' out to?
They are usually 4 numbers. I've thought that the first two were related to horsepower, though they don't always seem to match up real well
The second two, I'm not so sure about. I thought maybe it has to do with "frame size", but I can't seem to find a constant for that line of thinking.
Any and all explanations are greatly appreciated.
/ Kubota's sizing explained... #2
BX#### Sub compact utility
B####xxx Compact utility
L##xxx Medium utility
GL##xxx Deluxe medium utility
M####xxx Agricultural
# is numbers
x letters
The first two numbers after the letters for size are relative horsepower except some of the old ones like the B7100 etc.
The 3 and 4 number after the letter are the series like the BX has gone from BX2200, BX2230, BX2350 and now currently at BX2360 series. If it is just the two numbers after it is usually a TLB Tractor Loader Backhoe like BX26, L45 etc.
After that you have the letters in the sequence.
DT Gear drive
FST Fully synchronized transmission
GST Glide Shift
HSD Hydrostatic in B series?
HST Hydrostatic
C at end is cab designation
I am sure this is not entirely correct but is close to what I have figured out.
David Kb7uns
David_Kb7uns,
Thanks for the break down. That is a fair bit of typing you had to do.
Now, for the class review:
So, can a person say that the 3rd and 4th numbers are revisions or builds? Kind of like the British using Mark I,II,III IV, etc?
My L35 has the Glideshift transmission. How does this differ from the FST. Is the FST the Kubota way of saying, manual transmission?
/ Kubota's sizing explained... #4
I call the 3rd and 4th number the series, probably from JD. But I guess it could be called a revision. Basically same tractor just a newer "series" with some changes.
/ Kubota's sizing explained... #5
The FST is a fully synchronized manual transmission. You can shift it on the go, and shuttle on the go, but you're supposed to press the clutch to shift, just like shifting a manual transmission car. The GST (Glide Shift Transmission) is a full powershift with a power shuttle. There's no need to clutch the GST to change gears or shuttle. It has all of its gears in a line on the shifter and you just move the shifter up through them on the go. The FST has a 4 speed main transmission with shifting arranged in an H pattern like a car, with sub ranges on a separate shift lever.
Baucom,
Thanks for the explanation.
Old habits die hard I guess. I use the shuttle somewhat, without depressing the clutch pedal.
I almost always use the clutch pedal when I'm changing gears. If I just move the shift lever, I come to a complete stop before resume in the gear that I've chosen.
Is this the experience of other GST 'drivers'?
/ Kubota's sizing explained... #7
I always just shifted on-the-go, clutchless, & did the same with the shuttle at lower speeds.
/ Kubota's sizing explained... #8
Baucom,
I don't clutch going through the gears. I usually do forward to reverse mainly out of habit and it can't hurt right. I'm a work-it-hard kind of operator but never intentionally abuse any equipment....even rented stuff.
/ Kubota's sizing explained... #9
for most of the tractors, the model tells you the HP and the series of the tractor. My L3130 and L5030, the 31 and 50 are HP, the ending 30 is the Grand L30 series of tractor. '
These have been replaced by the Grand L40 series, so now you see L3240, etc.....
Just take a quick look at the Kubota web site.
/ Kubota's sizing explained... #10
The X300 series John Deere mowers can be confusing. The X324 is 22hp. The 2305 is 24 hp, the 2320 is also 24 hp. The 2720 is 31.7 hp and the 3520 is 37hp. The 3720 is 44hp. i used to think the first 2 numbers were the hp but they are just to confuse you. The 20 at the end just says it is part of the 20 series aswell as the 4x10, 4x00, x55, x50 series. How i can remember all this by memory is a story all its own.
Wow!
I thought the 'Orange Corporation's' system of naming models was convoluted. :laughing:
/ Kubota's sizing explained... #12
That pretty much extends throughout the JD product line and over many years. There have been so many models it probably just overwhelms any attempt at consistent naming, but you have to admire the die-hard JD fanatic's ability to internalize all those model designations. :D
/ Kubota's sizing explained... #13
I think the kubota naming convention is pretty easy. I like having the HP number in the model number, and being able to walk on a tractor lot and knowing the tractor size without having the manual. That's one of the reasons I first bought Kubota instead of a Deere.
Theoretically....
What do you think will happen when they used 90 as a Series revision? Since they seem to go by increments of 10 in the numbering process.
Do they go to 5 numbers to account for a XX100? Or, do they change and start going by smaller increments?
Not that ANY of this matters or amounts to a hill of beans. :D:laughing::laughing::laughing:
/ Kubota's sizing explained... #15
Perhaps they'll use hexadecimal. :p
/ Kubota's sizing explained... #16
Maybe they will do like CAT & JD on construction equipment and use a letter suffix. Lxx90B, Lxx90C, etc., followed by their transmission and cab designation. For example: L5290BHSTC--52 hp Grand L 90B series with HST & a cab.
Or maybe they will follow the automotive market and just develop a fixed model lineup and redesign it every few years without changing the model #.
Theoretically....
/ Kubota's sizing explained... #19
To revisit the transmission side-bar, the DT is not synchronized, to the point that Kubota puts a sticker on the dash warning you to depress the clutch and fully stop the tractor before shifting. Having said that, I've found that you can double-clutch and it's smooth as silk going up through the gears, not so good going down. 4 high is a bit tall for starting away. 3 high is fine, then I make the jump from 3 to 4 on the fly.
Sean
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
2015 John Deere 8345R (A64119)
2015 John Deere...
International S1900 (A63689)
International...
