3316 tool box, seat, grapple
/ 3316 tool box, seat, grapple #1
bnmccoy
Member
Edmond, Oklahoma
Mahindra 3316 HST & Fordson Dexta
I posted on another thread how I was installing a tool box from Atwoods that cost me $18 and was painted red. I welded a couple of lengths of tube on each end for a place to stick lynch pins when hooking up; saw this scheme on the end of the 3 pt. on some new LS tractors so I stuck the tubes on the end of the new tool box.
The tool box is not centered as I had the rear auxillary controls added which I use to open and close the grapple. I added a square tubing spacer to locate the SMV triangle to the rear so the tool box could be located more rearward to maintain a gap behind the seat and allow the seat to be moved more reward. You can't tell there is about 1" clearance between the box and seat from my pictures.
There is a picture of the square tubing adapters I made to allow mounting of the Iowa brand suspension seat from TS.
I rinsed the tractor with the hose prior to the pictures so there is water droplets all over the tractor. There is a plastic magnetic bowl to the right side of the seat in one picture; another handy holder for clips, etc. while hitching up.
I still need to finish my retractable seat belt brackets and add a rear light. Still on the fence as to adding a hard canopy. Need a drink holder too.
Bob
/ 3316 tool box, seat, grapple #2
Great looking mods. I am still trying to decide how I want to add a tool box to mine.
/ 3316 tool box, seat, grapple #3
Do you like the new seat substantially better? When I rake hay for hours the Mahindra seat leaves a little bit to be desired.
/ 3316 tool box, seat, grapple #4
Nice job on the mods! The DIY grapple is ambitious, indeed. I'm curious about the seat comfort also, as mine is in need of replacing.
/ 3316 tool box, seat, grapple #5
I purchased the Grapple from my tractor dealer. It is manufactured by:
Untitled Document
The dealer had experience with same on his 2815 or 2816; can't remember which.
Bob
I had the same seat on the Dexta and wanted a Mahindra branded suspension seat but never got the feedback requested of my dealer so just went ahead and bought this seat from Tractor Supply. It is as much better as the difference between night and day.
Bob
Bob, check out some of my improvements on my 3215. Some are similar to yours and some are ones that you are considering.
http://www.tractorbynet.com/forums/mahindra-owning-operating/158287-3215hst-improvements.html
I can not imagine not having a canopy. My poor old body would be burned beyond recognition if I didn't have my canopies.
Actually I looked at your mods early on and they have inspired me to make the changes on mine.
I want the canopy; but if I get it I really need to trim some trees or I'll rip it off! The canopy would be my answer to additonal lighting mounting.
Bob
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2017 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2017 GMC Sierra...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
