Oil & Fuel I found the level indicator
   / I found the level indicator #1
B2930 By the Water
Montreal, Canada
kubota 2920
I am a new B2920 owner and just found the hydraulic dip stick but, I did add too much oil. Does anyone know how to remove the excess hydraulic fluid. Also where is the best place to buy a repair manual or shop manual.
Thanks for your help,
Al
   / I found the level indicator #2
If you are a little over, leave it.. if a lot over, you can drain from a drain plug, of if you have a hydraulic line, open it and actuate that control... as to manuals watch Ebay and search on google... KennyV
Thanks Kenny,
I will do it tomorrow and let you know.
It is really appreciated,
Al
   / I found the level indicator #4
If you have some *clean* suitable clear plastic tubing, you might try siphoning some from the fill hole back into the container. You would have better control over how much you remove without making a mess or wasting it. ($$)
I don't suggest this unless you know how to siphon because you don't want to swallow any of it. Ideally you would use one of those cheap siphon pumps like they have at Harbor Freight, but you might not have one lying around.
Regarding an OM or WSM, assuming you can't find a used one, why not order it from the dealer or online at Messicks. As far as *good* repair manuals go, the price is not unreasonable at all.
   / I found the level indicator #5
   / I found the level indicator #6
* Does anyone know how to remove the excess hydraulic fluid. Also where is the best place to buy a repair manual or shop manual.
Al
Remove the drain plug and drain out about 3 or 4 quarts.
Check dipstick.
Slowly re add fluid if needed till it
reaches the full mark
Checking dip stick often.
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
