Noise in transmission
/ Noise in transmission #1
succor
Saskatoon, SK, Canada
foton 254
Hey there everyone, now that I found this forum I can get alot of useful info in here where I couldn't anywhere else. Anyway, when I run my foton for quite a while, say 2 -3 hours I get an occasion clunk or knock somewhere below me (can't pinpoint exactly where but it's the odd knock) only when I'm driving. So I'm guessing when it gets hot and driving maybe related to gear oil or something loose somewhere in the transmission. It drives fine, no slipping or anything and clutch seems good and I use 80w90 gear oil. Summer time here in Saskatchewan is on the cooler end around 22C. Is this oil too thin even though it's too specs or could there be something loose?? Any thoughts are always appreciated.
Thanks
/ Noise in transmission #2
Naw, 80W90 should be fine for 22C. I've found it to be a bit thin for July/Aug down here. Heat index today was 41C. So I thicken mine up with about 25% 85W140. Any more than that and it is too thick when starting up in the winter. But I think you're just fine with 80W90.
But before you start the tractor next time, check all your gear oil levels. I don't know how many you have on a Foton, but look for at least two; one for the tranny/rear diff, one for the mid-connect box (creeper or shuttle). If the mid-connect doesn't have a dipstick, remove the cover plate for a visual inspection. In addition to checking for correct levels, look for signs of water contamination. It often shows up as a pale yellow emulsion on the dipstick.
//greg//
Great, I will check this and let you know what I found out. As for these new alternators, are they still readily available. Up here we have partsource, canadiantire and of course gm dealers. I've seen a picture of the alternator, does it fit in place of these factory alternators or is there modifications?
Thanks
/ Noise in transmission #4
I can't comment on your particular tractor, the Foton which you say has a Mitsubishi engine, but *some* of the Delco 10Si and 12Si alternators are pretty much a straight bolt-on for the engines in most Jinma tractors. YOu have to get the right alternator, though - there are differences in the location of the terminals, for one thing.
The chief advantage of the Delco 12Si for me is that it will bolt righ to my Jinma 304's TY395Y engine and it makes the crappy Jinma voltage regulator redundant. I've had much trouble with my regulator and the alternator won't run all the lights so I'm changing mine out as soon as my new ignition shwitch and fuse block arrive. Gonna do a clean sweep on the tractor's flukey electrics and get things reliable for a change.
All I can suggest you do is obtain the measurements of the alternator you propose to use and make sure it will fit and that it has the appropriate pulley on it. For the Delco alternators you want a 2-1/2" diameter x 5/8" wide pulley in order to have it spin fast enough at your engine rpms to develop output. The Delcos come in both a 1-wire and a 3-wire configuration - I recommend the 3-wire since it will develop initial output at a lower rpm. The 1-wire has to get up to about 1200 engine rpm before it will self-excite.
Rich
The fotons and jinma's I think are pretty close to one another, Mine is a ft 254 25hp similar to the jinma 254. Proable should take the old stock alternator with me and compare at the parts desk. Now if I get the 3 wire unit, is there a wiring diagram for it. That would be useful to modify and get rid of the external regulator
thanks
/ Noise in transmission #6
Thanks
Yes, it's a direct drop-in - same footprint - even uses the same pulley, you just have to put the lockwasher on the backside of the pulley and use locktite on the nut. They will come with a wiring diagram.
I suggest you get the model with the closed face fan because this model draws air in through the rear which is cleaner - doesn't get the direct blast of crap from the radiator. You have to give the Chinese credit though, for installing a TEFC alternator in the first place. A Prestolite 65 amp TEFC alternator will run about $360.00 US.
This is a pic of my installation.
Hmm interesting, I went to partsource and they have a 10 and 12 si alternator but the footprint looked different being the mounted bolts were futher speaced apart from one another and bigger than my stock unit. Also the pulley's were different size but that could be swapped between the two. I'm not giving up though but I think there is some adjustability with the mounting bolts to make it fit.
Thanks for the pics!
/ Noise in transmission #8
I just did a 10SI on a JM 354 Jinma and put the wider pulley on and it took a long neck nut (special). The new pulley is counter bored and is the reason for the nut to fit inside the counter bore. Get the pulley and nut together as a "kit". I'm still tweaking alignment though. It looks like the new alternator needs to be moved forward about a 1/4" to get the belt to run true. bjr
/ Noise in transmission #9
Regarding your "clunk", I would check that the wheel bolts, and wheel weight bolts are tight. It doesn't seem likely that a clunk noise would be gear oil related.
Stan
Good thought Stan, I check the wheel bolts occasionally and they're tight. It sounds like it's from the gearbox straight below me. Almost like something is being thrown around in there. Next time it happens I'm going to put my legs against the box to see if I can feel something hit the walls inside to pinpoint it. If something was broken I would expect alot more rattling in the gearbox though. Because it's been so intermittent I was leaving it alone.
/ Noise in transmission #11
Hopefully you don't have anything metal circulating around in the gear oil, cuz it can destroy a gearset in a heartbeat. I know, I had to rebuild a transfer case already. But possibly the clunk is your transfer case arbitrarily disconnecting from the (front) driveshaft. That equates to the tractor jumping out of 4wd. Since 2wd (rear) is a constant, there's no "neutral" in between like with the gearshift or shuttle levers. It jumps straight from 4wd to 2wd, and the sound of the disconnect under load could be described as a "clunk"
//greg//
Wow you know that might be a possibility Greg because I'm having trouble with the 2 to 4 wheel shift lever beside me. Maybe it is popping in and out on the fly?? I was trying to adjust that lever underneath to no prevail because it seems like and can't shift from 4 to 2 properly or visa versa. Front tires skid when I put it in gear that's how I know that it is in 4 wheel. Could you elaborate on this Greg a bit. Again, good thinking!!
Thanks
Cory
/ Noise in transmission #13
Well, my KM454 would pop outa 4wd regularly. I'd look down, and find the lever had moved itself from 4wd to 2wd. But mine did it without the noise. At some point later, the lever finally stuck in 2wd. Usually I could get it working again by manually rocking one of the front tires while working the lever. That trick didn't work this time.
So I pulled the cover plate to see what I'd find. The sliding fork was definitely not moving, so I put the front tires up in the air again. Then while rocking a front tire, I tried moving the fork. This worked, and I was able to move the fork by hand between 2wd and 4wd. I cleaned the gasket and replaced the cover plate. Don't ask me why this worked, but the lever has worked freely ever since - and no longer pops out of 4wd either. But clearly something was binding, and something in that process I just described must have "unbound" it. Not very scientific, but that's the best I can do.
//greg//
/ Noise in transmission #14
Since you are new to Chinese Tractors here is what I have found working with 2 of them I have used. The 4x4 is easily engage while rolling and even making a slight turn seems to help. Trying to engage and dis-engage was tough when not moving.
The same is true for the diff locks on both.
Chris
/ Noise in transmission #15
Chris
Not sure about the Foton, but on my Jinma, the 4X4 and Differential lock mechanisms are two flat faced "pawl" devices that slide together and interlock. The pawl lookes basically like a 6 piece pie with every other piece missing. If you put two of these together, the 3 triangular pieces/teeth on one pawl will fit into the space between the 3 teeth on the other pawl. Because they are flat faced, they must be perfectly aligned before they will slide together. Like Chris said, rolling helps engage them, in fact, it is almost always a necessity, unless the teeth just happen to be in alignment when you pull on the 4X4 lever. To engage 4X4 or the difflock, while rolling(or with a rear wheel spinning:)), I apply gentle pressure to the control lever, and eventually the teeth align, and it falls right into 4X4 or difflock. Comming out of 4X4 is easy, just put some pressure on the lever, and it may come out easlly, depending if the pawl drive is under load at that moment. If it is stiff disengaging going forward, try it while rolling backward... For the difflock, I almost always have to turn the tractor from right to left to unload the difflock pawls so the spring will dissconnect them...
If the foton uses the same mechanism for 4X4 or difflock, I doubt it is making your noise, as it takes a little bit of travel and some applied force to engage/disengage, and I doubt that input happening by itself.
Can you determine if it happens in 2 or 4 wheel drive? that might help eliminate the transfer case or driveshaft... If yours is like most of these chinese tractors, it is probably dead easy to pull the top covers and expose most of the forward gearbox for a visual examination. The rear differential and PTO gearbox is probably another story:( A mechanics retrival magnet on a flexible handle is good for pushing down around the sides of the gears looking for any metal lying loose in the sump below the gears. You could have a broken piece of shift fork dancing around in there, occasionally falling against a spinning gear and being whacked out of the way by a gear tooth for it's trouble. Roll the gears over slowly by hand(will need to jack up a rear wheel, and or push in the clutch for this) looking for chipped gear teeth.
Better to find this sooner than later. As Greg mentioned, a stray piece of metal finding it's way into the wrong place will destroy a gearbox is short order...
Good points here everyone, I'm about to install my overflow container and take a closer look at this drive system to see what I can find.
Cory
Didn't open up the transfer case yet but I figured out the trick to move from 4 to 2 to 4 wheel drive. Just like everyone here said you have to have the tractor crawling a bit with the clutch in and it will shift very easily! Now I did some more mowing here with the unit in 2 wheel drive and I still heard the rattle or clunk just below me but not as frequent; more noticeable on a bumpy area. It is also there without the PTO driven which I remember as well. I'm now thinking worst case scenario that something is loose in there and I've been lucky so far. I'm not sure where to open up the unit yet but I'll have a closer look now. Any pictures or explanations would be much appreciated as always.
Thanks
Cory
/ Noise in transmission #18
When you say the noise is more noticeable on bumpy areas it makes me think that there may be something loose that is shifting on the bumps.
My tractor developed an oil leak that was the result of the flywheel housing not being properly bolted to the block at the factory. Something similar could be causing your "clunk." Check all the transmission, axle housing, bell housing and other bolts for tightness. If something is loose enough to shift around it will inevitably end up being a worse problem if left un-fixed.
Rich
/ Noise in transmission #19
You don't need the clutch to shift between 2 and 4 wheel drive on pretty much any 4X4 vehicle with engaged/locked hubs. The clutch only disconnects the engine from the transmission input shaft. The transfer case gets coupled into the transmission way back near the transmission output. When rolling, the front wheels are driving the front axle/diff, drive shaft and transfer case. The rear axle/diff/wheels are driving/being driven by the transmission output. When rolling, the 2 parts that couple together for 4X4 are rotating at nearly the same speed regardless of where the clutch pedal is. Just pull on the lever while driving, when the pawls align, it will fall into place. When disengaged, the pawls rotate at a slightly different speed due to gearing and tire differences between front and rear axle. Because of this, you only want to use 4WD on soft surfaces where the tires can slip. No slip, means extra transmission wear or something breaking
Dose it make the noise with the mower removed driving over the same terrain at the same speed? These cast iron transmission housings conduct noises pretty well. It could be the mower shifting/bumping thru the 3 point hitch...
Thanks
Cory
Cory, like I said, I am not specifically familliar with your tractor, but it is probably similar to most of these I have seen. Between your legs when seated are several gear levers for main transmission(1,2,3,R), Hi-Lo speed, Creeper and 2-4WD. Some of these levers may go in thru the side of the case(my 4WD lever does). The majority of the control levers probably go into cover plates that have 6 to 10 bolts holding them in place on top of the transmission case. You should be able to remove those bolts with a socket and lift the cover and it's lever up and away to look inside the gearboxes. Just note where the lever is located when you lift the plate clear, such as first gear, high range and creeper gear disengaged. Once you lift a cover plate up, it should be pretty easy to see where the underside of the lever needs to be returned to when you re-install the cover plate.
Yeh, it's the same thing without the pto so I'm going to take the advise seriously even though I don't want to open up the tranny, I'm going to anyway to make sure I don't damage it.
Thanks
Cory
King Kutter II Tiller for sale.
King Kutter II...
2021 CATERPILLAR 320 EXCAVATOR (A65053)
2021 CATERPILLAR...
Metaltech Climb and Go (A64553)
Metaltech Climb...
2022 EZ-GO ELITE...
2012 INTERNATIONAL DURASTAR 4300 SBA 4X2 CHIP TRK (A63276)
2012 INTERNATIONAL...
(40) 3'x8' HEAVY DUTY INSUALTED PANELS (A65055)
(40) 3'x8' HEAVY...
