HF Three Point Log Splitter
/ HF Three Point Log Splitter #81
Impdaddy et All,
I bought 2x60" (5 foot) hoses with 1/2"NPT on the splitter end and 3/8"NPT on the tractor end. I have the Kubota rear remotes and the quick connects take a 3/8"NPT fitting hence why one end of the hose is different than the other. The hoses are 1/2" diameter and are rated for 3,500PSI. The pair of them cost me about $105.00 at NAPA. The hardest part was explaining to the NAPA clerk the difference between NPT and the flared fitting he kept thinking was NPT.
I cannot speak to the quick hitch as I did not use one. I probably should get one as hooking up 3PH attachments can be a PITA. BTW, I have an L3400HST. I will say that I bolted together the splitter in about 10 minutes...it was quite easy.
I was expecting something with a crappy paint job and that was not assembled well since it was from China and cheap (like when you buy something from Grizzly!), but I can honestly say that it is a sharp looking splitter.
My hydraulic pump is not much different than the one on the BX series...I believe close to the same GPM, atleast within a few GPM. The cycle time on it is a little slow compared to most splitters I have rented but honestly it is a perfect speed for my ability to load the splitter. While the majority of the splitters I have used are faster, the ram spends most of its time retracted waiting for me to load the next 100lb log. I run my L3400 at about 2,000RPM while splitting. This seems to generate a perfect cycle time for me based on my speed.
I was not convinced on the 3PH splitter, and I was also confused as to get one with a PTO pump or that used my rear remotes. I can say clearly that I made the right decision. The cycle time is fine for my ability and the cost savings was tremendous. There is no point in getting a splitter with a 10 second cycle time if it takes you longer than 10 seconds to load the logs.
I also LOVE being able to raise the splitter up to not bust my back, but lower it to the ground if I have a really heavy log to roll onto it. Let the tractor do the work!
I spent some time splitting some oak from a tree that was just cut 2 weeks ago. I could literally see water coming out of it while it was hitting the wedge because it was so wet. Wet wood is one of the hardest splitting tasks for any splitter, but it split it just fine.
One of the pieces I split was a little under 36" in diameter. I had to lower the splitter to the ground to roll it onto it, but it split it just fine. I think I spent 5 minutes just on that piece continuously splitting the bigger pieces into stove sized logs. So, in short, you have to be careful, but 16" diameter logs is certainly no limitation of this unit.
I don't have a harbor freight near me, but I was able to use the 20% coupon anyways. I called the 1-800 number and told them I drove 1 1/2 hours to a store to buy it but the store was out of stock and told me I would have to call to order...Of course I never made the drive and didn't know if that store had one or not...They took the coupon over the phone and gave it to me for $399 anyways. I had to pay $105 freight, so it was $503.93 delivered.
With hoses, the total cost was $608.93. Not a bad price for what appears to be an awesome and very capable splitter.
Good find guys. Thanks to all the forum members that wrote up their experiences on this one. I bought it with some confidence knowing that the trail had already been blazed!
---Aaron
/ HF Three Point Log Splitter #83
Yes, it does. I was also considering PTO pump models as well from other manufacturers. I am glad I got this one however as I do not believe I need the extra cycle time / power of a PTO pump model such as one from Iron & Oak.
---Aaron
/ HF Three Point Log Splitter #84
well i dont have outputs so i guess no dice on this one. I am looking for a seperate splitter, but you cant find one for less than this thing costs new. I originally did not want a 3pt splitter b/c of the use and tractor hours. But then someone pointed out what it you split wood for 5 hours a year after 20 years that only 100 hours. And that would be if you were at full operating speed, i think i could cheat down to about 1700rpm and not loose my torque to run it and thus saving hours on the meter as it turns 1 hr at 2400rpm
/ HF Three Point Log Splitter #85
I bought a similar splitter last year, though not from HF, and mine is red.
As others have mentioned, the bolts that come with it are not exactly up to the task, especially for the top link mounting.
So far I have bent nearly everything that attaches to the 3pt, and the welds on the wedge are all starting to crack.
I have re-welded a few spots, but i'm dubious of the iron content. As a friend of mine would say, its made of "metal" not steel.
/ HF Three Point Log Splitter #86
For those that run log splitters from their tractor...
Do you guys (and/or gals) use the remotes on the tractor to control the log splitter or do you use the valve on the log splitter itself? Seems like you would want to use the remotes on the tractor... but wouldn't you have to bypass the valve on the splitter? Or vice versa if you were using the valve on the splitter?
/ HF Three Point Log Splitter #87
if you run it from the remotes on the tractor for split/retract, you have to get off every time to put the log on.
/ HF Three Point Log Splitter #89
I dont' have to get on my tractor to pull on the remotes' lever(s).
/ HF Three Point Log Splitter #90
Maybe so, but you'd have to step away from the splitter. The easier way is to bungee the tractor's remote lever to open and then use the splitter's valve to control the ram. I'd say that is the norm for operators of 3PH splitters using remotes.
/ HF Three Point Log Splitter #91
My tractor has rear remotes for the backhoe. I just connect the hoses from the splitter to the remote. Set the engine RPM to 1800ish and go to work.
I bought a 3PH splitter since it was cheaper, better, and one less engine to have to manage.
Mine works just fine.
Later,
Dan
/ HF Three Point Log Splitter #92
Thanks. I was curious how this worked if someone was connecting in to their remotes.
So let me ask you this, what is the purpose of a self cancelling detent valve on the tractor. It seems to me a log splitter would be the obvious reason here... but if you are really using the valve on the log splitter, it sounds like the valve type on the tractor doesn't matter. I ask this as I am genuinly curious. On my tractor I have one self canceling detent valve and one float detent valve. I get the many uses for float... but I am having a hard time figuring out what use the self canceling valve can serve. Of course the self canceling detent can be used as a valve for anything... but it is the self canceling feature when in the detent position that I don't know what implement would use.
/ HF Three Point Log Splitter #93
I got interested in this thread after a neighbor gave me his old 3 pt wood splitter. (see picture below)
As you can see it need cylinders, valves, hoses, paint and maybe something else.
Question one: Would it be more practical to get the harbor freight 3pt wood splitter?
I went to Harbor Freight today and saw their electric 7 ton splitter for about the same price. Since my WBS only holds wood 23" long by 8" wide. I burn about a cord a year, a cold year. it looked very interesting.
7 Ton Log Splitter
Question two: Would it be better for me to get the portable electric 7 ton splitter?
/ HF Three Point Log Splitter #94
7 Ton Log Splitter
It may depend on what wood species you are splitting. Easy or hard? For ~one cord, it might be cheaper to rent a splitter once a year for a day.
Dave.
/ HF Three Point Log Splitter #95
I'm splitting post oak and blackjack oak wood. I am leaning toward the electric one because I usually just go out into the woods a few days before a cold front hits and cut down a dead tree (I have many). The trees are not more than 18" in diameter. I usually keep the BH on the tractor and I would not have to change out several times a winter. Is 7 tons enough power?
Renting one would make me work too hard in a short period of time and cramp my retirement lifestyle.:D:D:D
/ HF Three Point Log Splitter #96
Lifestyle is important! :)
I've never split dead post or blackjack oaks, so I don't have the answer. Red oak is an easy splitter, especially when it is from a live tree and freshly cut.
A good way to judge is to split some by hand. If you can split them with an axe or 6lb splitting maul with one or two good hits, they are easy splitters and I would guess most of the straight rounds could be split with 7 tons.
I split about one cord by hand with an 8lb splitting maul. The crotchety pieces go to the firepit supply pile. It's good exercise on a 50* or less day. It's usually Fall and I spend a fair amount of time enjoying the leaves and generally standing around gawking between minor bouts of splitting. :D
Dave.
/ HF Three Point Log Splitter #97
Nothing is wrong with your questions. At some point, we all either asked the same questions or learned from experience.:thumbsup:
I have to admit that I'm not 100% positive what a "self-canceling" valve is. I suspect it may be like a log-splitter valve where you can set a back pressure where the valve will automatically go to center, thereby cancelling its operation. It would keep the hydraulics from going into relief if the maximum pressure is reached. That makes sense, but I'm not sure it is correct.
A log splitter valve has something similar to the "self-canceling" feature. When you move the valve's control lever to advance the ram, full pressure is applied for as long as you hold the valve in the advance position. After splitting the log, you can move the lever to the full retract detent position and remove your hand. You don't have to hold the valve open while the ram retracts. You can be repositioning your split round for the next cut. When the ram gets to the the full retract position, there is a pressure spike that pops the control handle back to neutral and removes pressure.
I would say that on your Kubota, you would probably want the aux valve set on the tractor to "self-cancel" unless it constantly pops back to neutral and becomes a pain to reset over and over. In that case, I'd bungee it to the full open position and be done with it. When operating your splitter, you have your hand on the control valve always while the ram advances, and you will move it to retract if the ram stalls. Splitter valves are quite simple and quite functional all at the same time. Good stuff!:)
/ HF Three Point Log Splitter #98
7 Ton Log Splitter
Don, I'm going to come down firmly on the side of the HF 3PH splitter instead of the electric one. The reason is that my 3PH splitter is just about right for exactly the types of splitting jobs you're describing. My postoaks and blackjack oaks are knarly, twisted, and crochety. I've hit some spots that challenged the 14-ton 3PH model. It does a good all-around job. It will cost you less than refurbing the old splitter and be less likely to burn up a motor than the electric HF splitter. I just hear way too many horror stories about HF electrical powered handtools burning up. I admit that my paranoia would keep me away from that electrical unit.
Here's another thought about the splitter. There is no reason that the 3PH splitter cannot be mounted on a cart or wagon. Sure, it's made to go onto a 3PH, but you could put some hold-down clips on a trailer and just run longer hoses to your tractor's remotes without messing with the BH. You can tow it wherever you need to use it on the trailer and use the flat surface it is mounted on for workspace to roll big rounds onto the splitter and also catch split rounds to keep them from falling on your toes. I have the bruised big toe to testify that it can hurt. Ouch!
My point is that the 3PH model is more flexible than it first appears if you consider that all it needs is to be attached to your tractor's hydraulics. If you think I'm considering buying a small trailer to mount mine on and pull behind my tractor when I go splittin', well, that would be a very accurate guess. Being able to disconnect quickly from the splitter and go use my tractor and grapple bucket to bring wood to the splitter is something I've been considering. Right now, I cut rounds with my chainsaw while holding the wood with the grapple. Then, I back the tractor with the splitter up to the Kawasaki Mule and sit the splitter into its bed. I use the tailgate of the Mule to catch split rounds and then toss them into a big stack in the Mule. When the Mule gets full, I haul the split wood off to my woodpile. That way I don't have to try and haul a big tree out of the woods and across all my gullys. I can cut and split onsite while using the Mule to haul. Of course, Kathy helps with driving the Mule. If I had the splitter attached to a trailer, I could just pull the trailer behind the tractor and make it a 1-person job.
/ HF Three Point Log Splitter #99
My 3PH splitter does not attach to my tractor anymore. :D I move it around with my pallet forks. :thumbsup: I built a bench that holds the splitter. The bench is about 5 feet long and 3 feet wide. It holds the splitter, wood to be split and wood that is being split. This minimizes me bendng over. :thumbsup: I also built a little table roughly 2x2 that helps hold wood that is being split.
I don't move the bench really. I just moved it into place and there it stays. I cut the trees into 6-8 foot long logs which I move to the splitter with the pallet forks. Much easier to move the logs than the wood rounds. The logs get cut up into rounds near the bench/splitter and then are split right there. I can just toss the split wood to where it needs to be stacked. The fewer touches on the wood the less work. :thumbsup:
I back the tractor up to the bench and connect the hydraulic hoses. Easy peasy. I think I will get some longer hoses one day so I can park the tractor parallel to the bench to connect the hoses. The current hoses need to be a couple feet longer to do this. :( That way I don't have to take off the MX 6 to split wood. So far this has not been an issue so I just use the "short" hoses.
Later,
Dan
/ HF Three Point Log Splitter #100
Jim thanks for the info on our like wood, that helped a lot. Using a trailer or pallet forks made the decision easy to double the tons. When I saw the special price that Harbor freight now has, the refurbishing of the old one seemed pointless. I might just be enthused enough now to do more than one tree at a time. Thanks:)
Shuttle Bus (A61573)
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
Schulte XH1500 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Schulte XH1500...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
Crate of Misc. Parts (A64119)
Crate of Misc...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
