4510 coolant color
/ 4510 coolant color #1
yanmars
I just replaced the green coolant in my 2004 Mahindra 4510. I replaced it with DexCool, the orange General Motors coolant. I then read the most recent Popular Mechanics magazine and it said one should never use other than the original color as it can be hard on gaskets, water pumps etc.
I am not sure what the original color coolant in the 4510 was, perhaps mine was changed before I bought it. Does anyone know the original color and has anyone had trouble with the other colors? If so I guess I will rechange it again. I also used green in my Dodge Ram truck and perhaps that is wrong also. Thanks
/ 4510 coolant color #2
I don't think putting Dex-cool in was a good idea, I would drain it well ( the radiator and block) flush it with clear water and fill it with regular ethalene glycol. (Please excuse the spelling) If someone knows I am wrong about this, please chime in.
/ 4510 coolant color #3
Drain the "Dexcool" for sure. It should be filled with a low silicate anti freeze. I think that the "Fleetgaurd" that is available at tractor supply should serve just fine, or just get it at the dealer. The cost should not be the deciding factor since it is something that is drained every couple of years.
Get the Dexcool out ASAP.
/ 4510 coolant color #4
I have a 4110 and I use the green stuff. I never really thought about about color after having radiator fixed. I read the PM article too. Interesting. I wonder, in a few years there will be more colors antifreeze to choose from than there is Coke to choose from.
Cheers Coffeeman
Thanks for the information.
/ 4510 coolant color #6
Keep in mind that there are coolants made for diesel engines that deal with the cavatation around the upper cylinder, you may want to consider such a coolant.
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A67148)
2019 ISUZU NPR...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
2015 TAKEUCHI TB280FR EXCAVATOR (A65053)
2015 TAKEUCHI...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
