Posthole Digger PHD conversion to hydraulic??
/ PHD conversion to hydraulic?? #1
ss4010
Santa Cruz CA
BobCat CT230
Hi All,
Since there is an impressive array of people on this site way more experienced than me with such matters, it seems appropriate to submit the following for your consideration.
I have been toying with the idea of converting my current Post Hole Digger from PTO driven to a hydraulic drive. Purchasing a Belltec or similar unit up front would make more sense but the current PHD I have was "free" with the tractor purchase. So the question is: sell the current unit (it has 20 or so holes) or try a conversion using a hydraulic motor coupled to my existing gearbox.
Essentially I have some steep hills and will need to drill uphill of my tractor, so a FEL mount makes sense.
There appear to be a few units out there similar to my vision. One example is the Land Pride HD25.
Land Pride HD25 Post Hole Diggers
So my current PHD is a Bobcat (re-branded Rhino?) and appears to have four 1/4" holes drilled and taped around where the PTO shaft couples to the gearbox. I'm thinking this might make it easy to attach a mounting flange, but may require larger bolts (drilling and tapping) to handle the torque. The gearbox is a 3.81:1 reduction.
The remotes on my Bobcat CT230 are rated at 7.9 gal/min and the relief is set for 2711 psi (if I'm not mistaken). Running that through
Hydraulic Motor Calculator
gives me 8.1 HP. If that is inadequate a PTO driven pump could be in the running for consideration.
Below are some pictures of my unit as it sits.
Essentially it seems that no more than 300 RPM would be required. Some things I'm not certain about are whether a relief in the motor will be required (or will the tractors relief valve be suitable for the remote). Will I need to increase the bolt size or will grade 8 1/4" bolts be acceptable (seems quite small to me).
The bolt spacing pattern on the existing PHD appears to be 2 5/8" square OC? or 3.625" in diameter? with the overall square portion being 3 1/2". The input shaft to the gear box is 1 1/4" diameter (shear bolt, no key) by 2 1/4" long.
I'm thinking a motor, motor mount, bucket mount and a coupling are the required components (beside hydraulic hose and fittings).
I'm a bit in the dark about the hydraulic motor mounts. It seems like a PEM-F is what would match up to the gear box.
Pump Motor Adapter/Dampening Flanges - Gas Engine Adapters by Vescor Corporation
It would seem surplus center has a mount that may work:
https://www.surpluscenter.com/item.asp?item=1-3238&catname=hydraulic
Has anyone else attempted such a conversion? Perhaps some of you have units like the Land Pride HD25 and can chime in on what hydraulic motor it uses and how it performs?
With the plethora of hydraulic motors out there any guidance would be appreciated. I'm not sure where to really begin with the range of variables out there. How important is the PSI rating on the motor? For example would I need to match the PSI rating on the motor to my relief valve pressure?
Would something like
https://www.surpluscenter.com/item.asp?item=9-7751&catname=hydraulic
be suitable with at 10-12 GPM rating at 1750 psi? My remote is rated for 7.9 GPM, so would that just mean the motor spins slower than the rated 460-540 RPM. I image the rated capacity of the remote is at max engine RPM's I would want to keep the tractor RPM's down so would that mean that something like
https://www.surpluscenter.com/item.asp?item=9-3516&catname=hydraulic
(3 ci 7 GPM max flow, 539 RPM)
would be more appropriate?
I'll stop rambling for now and look forward to comments and guidance.
Thanks,
Steve
/ PHD conversion to hydraulic?? #2
I converted a SpeeCo digger to hydraulic 10 years or so ago. I originally used it on the FEL but drilling holes straight (vertical) was a challenge due to the arc the loader travels in. Down pressure was the reason for doing it. About 5 years ago I got ambitious and built a frame that guides the head and has a hydraulic cylinder to provide the travel and down pressure (kind of like drilling rig). I run it with a 12 gpm (I think) PTO pump and it has a 15 gallon reservoir and a 2 spool valve. I made it to fit both the BX22 and a Category 2 3-point. I chain the mast to the drawbar so I can put the weight of the tractor on the auger. It works pretty good.
I made the hydraulic motor mount to bolt where the PTO guard was. They were metric bolts and either 8 or 10 mm. I coupled it up with a LoveJoy coupling. I had 2 CharLynn motors of different displacements. The first I tried ran it about the same speed as the PTO would but it didn't have enough torque to dig. I changed to the bigger displacement motor and although it is a little on the slow side it digs fine. All the materials except for the valve and hoses was stuff I had laying around or was pilfered from other projects. I can't tell you what the displacement of the motor is without looking or what the reduction of the head is. I think the relief on my valve was set to 1500 psi which was the rating of the motor.
I would drill and tap the holes out 3/8 or what ever the bolt hole size is on the adapter if you can. Can't say that the 1/4 wouldn't work but bigger is better. You'll also need to make sure the adapter is the right length face to face for your shaft lengths. I would look for a motor close to or more that the psi rating of the tractor so you will have the maximum torque. Not sure that the Surplus Center mount would be strong enough going by it's HP rating. It does resemble what I made though.
I'll try and get the displacement of the motor I used so you have something to go by. Might take me a day or two. Definitely a doable project.
Kim
Hi Kim,
Pictures of your setup would be great. Without even starting it looks like mission creep may be setting in on my project. I'd also be interested in the size of the PTO pump you used.
My limit for newly purchased parts is $450 for this project (excluding mount and hoses). Any more than that and I will just buy a Belltec or similar.
Belltec Hydraulic Planetary Auger Drive 6-15 GPM, Model# NC150 | Auger Powerheads, Bits + Extensions | Northern Tool + Equipment
A motor mounting bracket could be fabricated out of 1/4" steel or such, should the cast al pre made brackets be too weak.
Thanks,
Steve
Kim
/ PHD conversion to hydraulic?? #4
Hi Kim,
Steve;
I'll see if I can get some pictures of it and figure out how to post them. This will be a first for me. The pump is a bit of a mystery because it came off an old Koyker loader. Thinking about it's probably less that 12 GPM, maybe only 8 or so. I'll see if I can come up with some info on it as well as the motor. Might be the weekend before you see anything.
Kim
Just realized that I never added the pictures to the thread. Here are pictures of the PHD as it sits...
/ PHD conversion to hydraulic?? #6
Steve; The motor I used on the digger is a CharLynn 101-1008-07 which is a 20 cu/in. With any luck there will be pictures
WOW... That is one serious sexy beast of a machine!! Thanks for the pics and the stats on the hydraulic motor. If I go that route, I will post pics of my contraption.
/ PHD conversion to hydraulic?? #8
I was kind of questioning the 20 cu./in. on that motor so I looked it up on CharLynn's site and it is actually 22.6 cu./in., 1250 PSI and 15 GPM max. I would think if you can find a higher PSI rated motor you could make do with a smaller cu./in. motor and get the RPM up. That was a motor I had and made work. Probably not the optimum motor. If I do have a 12 GPM pump I'm only turning the motor 122 RPM. I don't know what the reduction is on the digger head. Kind of need to know that. Should probably be looking at the in./lb. of torque number along with the gear reduction. I couldn't turn the auger to determine the reduction. I don't know your time frame for this project, but I do have some fencing to do yet this year but I'm currently building a garage. If I get the digger on a tractor I could check the ratio. Might not happen until fall. I had intentions of getting the thing painted but had a few mods I was going to do 1st, but never got around to it.
Kim
/ PHD conversion to hydraulic?? #9
I just went back to the motor site and the in./lb. of torque number is 3347. I wouldn't want less than that.
Kim
/ PHD conversion to hydraulic?? #10
Steve I don't think pointing you tractor up a steep hill and then applying down force with the loader sounds like a very safe thing to do. I am not sure how steep you are talking about when you say steep. I do think a loader mounted phd sounds sounds good for several obvious reasons.
It's high time I update my own thread.
So after some input and searching what was available (mostly at Surplus Center) I ended up using a 6 ci displacement hydraulic motor coupled to my current PHD gearbox. I used a hydraulic motor to gas engine mount (of the shelf component) and did some minor machining on the drill press to make everything bolt together. I picked a motor with the same diameter output (1 1.4") as the input to the gear box. It is assembled with a solid steel coupling and a flywheel key on the motor side and a through bolt on the gear box side.
Here is a picture of the first test run with the auger attached to the rear.
Bolstered by my success drilling some practice holes at idle and at PTO speeds, it seems the size of the motor was about right for the capacity of my rear remotes. At idle its a nice slow rotation. At PTO speed the auger spins fast enough to whip the dirt off the auger drive.
The next step was to mount the device to the FEL so I could drill holes up slope and deep holes down slope of the tractor. The receiver welded to the top of the bucket (idea "borrowed" from TBN), seemed to be a good platform for attachment. So a 2 way swivel was fabricated to allow the auger to remain plumb. A stop was added to prevent the motor / hoses from hitting anything during transport. And a pin on bracket was used to prevent the auger from swinging side to side during transport.
You can see the pictures of the project now under way. Essentially drilling deep footings on the uphill side of the deck to prevent it from sinking into the ground further. Over the course of time the up slope side of the deck has sunk into the ground more than 10". It appears that the existing (crazy shallow) footers are sitting on non compacted clay fill and organic matter.
Some of the lower footers will also be drilled at a slight angle from the access "road" that I cut below the deck in 2009. The FEL mount allow me to raise the auger up higher above ground level than I could before using the rear mounted version.
Today I picked up a combined 38 tons of CMix and base rock to begin pouring new footers and compacting the base rock in the dirt area under the deck to minimize water infiltration and settling. As you can see this small dimension on the deck is 28 foot long, so this redwood beast is over 1000 sf, so the replacement cost could be quite substantial should it "slide down the hill".
Here are the pics...
For the safety police... It seem appropriate to add a picture of the rear ballast hanging out back (along with my latest mod, the tilt). This box beast came of a retired circa 1970 skip loader and has 3/8" thick steel. At 77" its way too big for the tractor, but it's main use is ballast and spreading base rock on the community road at which it does a fine job. Too bad the tail board was lost over two decades ago. My rears are also loaded, as you can see the hills here are SCARY!! I'll take all the weight I can get just above ground level.
/ PHD conversion to hydraulic?? #14
Good job! Thanks for the update.
Kim
/ PHD conversion to hydraulic?? #15
ss4010
Do you have the link to the exact motor you used?
If you dont mind what cost was involved, you started with a $450 budget.
Thanks
/ PHD conversion to hydraulic?? #16
Nice job SS4010.
I've often thought it would be handy to have a 3-point hitch and PTO on the front loader. The way I would make it is to put a front 3-point hitch adapter on, and a hydraulic motor with a six-spline output shaft. On the rear I'd put a PTO hydraulic pump.
If the hydraulic pump and motor have the same volume per revolution they would spin at the same speed.
It seems like there's a lot of implements that would be handy that way -- you get down pressure, float, much finer adjustment of angle, a greater range of height. The PHD would be handy, but what I'd be really curious to try is the rotary mower!
ss4010
Thanks
Hi Sharkey,
Here's the breakdown on the parts (all from Surplus center)
https://www.surpluscenter.com/item.asp?catname=&qty=1&item=9-7490
9-7490 Motor 6.09 ci $135.50
1-3228 Hyd Pump Mount SAE A $37.95
9-6901-10-8 SAE 10M x 1/2 NPTF 90 swivels $11.00
****1-1563-G Shaft Coupler 1 1/4" $14.95 ****
Plus Hose, quick couplers, scrap steel and some bolts and pins for roughly another $100.00.
*** Note the shaft coupler was a mistake. The key way was not the same size as the key way on the hydraulic motor. So it had to be opened up to a larger size (8mm (roughly 5.16")) instead of 1/4" to fit the hydraulic motor.*** Surplus Center does sell the larger key way rigid coupler.
The motor was selected using two criteria:
1. The shaft type and diameter matched the size of the input for the Auger Gear box I already had. So a rigid coupler could be used.
2. The displacement was calculated using the gear ratio of the Auger Box and the output of my rear remotes (7.9 GPM) to turn at the desired rate of rotation depending on the engine speed. It's nice and slow at low engine speed and fast enough to sling the dirt out of my 15" auger at a high engine speed. I used the Surplus center online calculator to determine RPM at GPM.
Some minor (drill press) machining was required on the motor mount. The coupler needed to be cut to length, drilled and the key way opened up to the correct size. The swivel, brackets and rest were fabed and welded from roughly $30 of 1/4" steel tubing (plus some angle which I already had around).
All said and done the cost came in around $300 - $350.
Steve
Nice job SS4010.
I like that idea too! It was a little out of the scope (read budget) for my requirements. Plus I only have a 22 PTO HP machine, so something like a rotary mower (up front) would have to be pretty small to work with my hydraulic capacity after the conversion losses.
2015 Ford Transit 350 Sewer Viewer Van (A61568)
2015 Ford Transit...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2020 Mack Anthem...
2002 INTERNATIONAL 4700 4X2 LANDSCAPING TRUCK (A59908)
2002 INTERNATIONAL...
2019 CATERPILLAR 305E2CR EXCAVATOR (A62129)
2019 CATERPILLAR...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
Cummins 6-Cylinder Diesel Engine with Transmission (A61568)
Cummins 6-Cylinder...
