TSC universal steering wheel knob.....
   / TSC universal steering wheel knob..... #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
Anyone know the deal with these things? I picked one up today from tractor supply. This thing will not go on the steering correctly. The ends on the main bracket hang off the sides and the two clamp brackets they give you can't be secured (bolts are to short) without forcing them tight with pliers, which causes everything to gouge into the steering wheel.
Are they just junk?
   / TSC universal steering wheel knob..... #2
Can't comment on the quality of the item you bought, but, when I mounted my steering knob I clamped it over a section of inner tube which I wrapped around the wheel. No gouging; hasn't loosened or slipped in in 10 years -and I do not have power steering.
   / TSC universal steering wheel knob..... #3
Key word is 'universal'. Kubota makes a very nice steering knob but it's a bit costly. I find that a steering knob is an absolute necessity especially when mowing.
thanks for reading and carry on
glen
   / TSC universal steering wheel knob..... #4
Try mounting it where one of the center supports intersects with the outer steering wheel. I bought one from a similar farm and ranch store here and it worked fine on my Kubota steering wheel.
Any chance you snag a pic and post it? I'd like to see how the bracket is sitting on the steering wheel.
   / TSC universal steering wheel knob..... #6
Lots of different ways to mount these things and most of the successful ways involve some modification of the bracket. If you need to do that in order to get the knob in the right place in respect to straight wheels(very important for easy use and comfort) then do so. IMO the correct position is paramount to even having the thing to begin with.
glen
   / TSC universal steering wheel knob..... #7
glen
But with the hydrostatic steering that is on all the newer machines the knob will NEVER be in the same place when the wheels are straight;)
   / TSC universal steering wheel knob..... #8
Sorry no pics for you but I think mine was a TSC universal too (silver steel)
And I ended up having one of the two bolts go thru the centre support of the steering wheel. But just a small hole drilled in it and it hasn't moved since .
Advantage of Drilling the centre arm is that there is no way for knob to work its way around the wheel because it is more than just friction preventing it now.
I find the knob very useful no matter where the wheel ends up (with hydrostatic steering,)
   / TSC universal steering wheel knob..... #10
I purchased the same steering knob and had the same issues you are describing. I returned it and went to Lowes and purchased the one in my attached picture. Fits well and I went ahead and put two on since it never stays in the same position on a HST steering tractor.
Loader with IH Brackets (A50515)
Loader with IH...
Taylor Dunn Big Foot Electric Cart (A50324)
Taylor Dunn Big...
2006 Volvo VNL (A52128)
2006 Volvo VNL...
(INOP) TAKEUCHI TL12R2 SKID STEER (A51242)
(INOP) TAKEUCHI...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
