Oil & Fuel Diesel pump belarus 250
/ Diesel pump belarus 250 #1
niva
Belarus 250 / T25A
I recently bought a Belarus 250 or as it called here in Poland (where I live) a Wladimirec T25A.
The previous owner told me that he had the diesel pump adjusted for less power and better fuel economy. I would prefer to have a bit more power and slightly worse fuel economy. Can I adjust things on the pump myself ? Do I use the by plastic covered screws on the top of the pump?
I just opened the oil level screw on the side of the pump and a lot of oil mixed with diesel flushed out. I drained it and put new engine oil in. Maybe this will also help.
Hope somebody can help me. I have a bit of a language problem here, being a Dutchmen in Poland.
Many thx
/ Diesel pump belarus 250 #2
This is an adjustment that you should really have a Mechanic do it. But since there are few Belarus dealers out there..... The screws on top of the pump are the start-stop range. I would suggest you go on line to e-bay and get the manual. It tells you what every thing is, but does not give specifics on adjustment.
Sorry I could not help you future.
/ Diesel pump belarus 250 #3
Many thx
Can you post a picture of that injection pump,maybe i can help.
From a dutchman in Canada;)
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
Zero Turn Mower (A59231)
Zero Turn Mower...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A59911)
2018 INTERNATIONAL...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
iDrive TDS-2010H...
