Backhoe Mahindra complaint
/ Mahindra complaint #1
s78wingrider
Gold Member
Hardy Co. WV
Mahindra 3215 gear
I think Mahindra should stand behind the junk backhoe's they sell with their Tractors! I have a 3215 with 3710 hoe with less than 400 hrs. Broke the 3rd plastic weak link piece in joystick control last evening. This hoe was greased probably more than normal, but pins and bushings (if there's any there?) are shot????? Complete joystick control units are also shot! Love the tractor but these hoes are junk
/ Mahindra complaint #2
Can you take a picture of this weak plastic piece. I have a 3710 hoe and I don't know what joy stick you are referring to. Thanks, Bob.
I'm thinking of taking new one I have to machine shop and see what it would cost to get 4 made out of metal
Is the handle it self all plastic?? No, just the one piece
/ Mahindra complaint #8
I am not clear if you are slamming Mahindra for not selling each individual part for your tractor/backhoe or just ticked because to fix it costs more than you think you should spend? I priced a fan switch for my 2002 Ram 2500 diesel. In the old days, the fan switch would be a few bucks and it was easy to replace. Now, I have to pay $198 for the whole air conditioning 3 switch module and rip out the whole dash. How old is your tractor. Small plastic pieces tend to dry out and crack out. Get one made out of teflon. It is self lubricating.
So what is this about the pins and bushings being shot and probably greased more than normal? Sounds like someone else does the maintenance. What type of grease is it? Excess grease attracts and traps dirt. Are all the pins and bushings worn, or just the swing bushings or the boom pivot bushings? Isolated wear usually indicates abuse. Is this rig doing the work a bigger machine should be doing?
hug, Brandi
/ Mahindra complaint #9
I'm not keen on the idea of plastic parts in a hydraulic valve either. I can't speak to the bushings and such but in a valve bank is just waiting to fail, IMHO.
My guess is OP's comments about the bushings is frustration showing through. Of course, if I broke my 3rd plastic joystick part, I'd be frustrated, too.
I do agree, however, with realizing that smaller hoes have to be made lighter and aren't made to do the things larger hoes are made for.
(But plastic parts in the hydraulic valve bank still bothers me) <-- Did I say that already ;)
- JC
I do agree, however, with realizing that smaller hoes have to be made lighter and aren't made to do the things larger hoes are made for.--- But shouldn't it hold up to what it will do?
/ Mahindra complaint #11
Yep! ;)
-JC
/ Mahindra complaint #12
I do agree that plastic parts in a component, such as a valve that continually moves, is hideous. It makes us owner/operators buy complete replacement units.........pushing their $ profit higher. I find myself. often, after pricing a replacement part.........trying to figure out how to make or modify a replacement.
I guess since the valve was not made by Mahindra, it can not stand up to the use the normal Mahindra tractor sees. I had an issue with my Bradhoe 511, in warranty, with boom pivot bushings, until my Mahindra dealer added shims. It still has more play than I think it should. We just got to understand backhoes.. ..........of all equipment we hang and work off our tractors.........get the most abuse, as it is the nature of moving parts repeatedly stuck in dirt.
hugs, Brandi
/ Mahindra complaint #13
If your pins are worn badly already, you aren't getting enough grease where it needs to be, or you are not getting it there often enough. We will often see a bunch of grease all over a plugged zert (spelling?), but no grease on the pins.
As to the broken plastic rod ends...yeah, that wasn't such a good idea and they no longer use that valve system and haven't for a while. However, the rod ends are available separate from the assembly and not many people break them. Bot those that do break them, break them often. :eek: Probably some people have a heavier hand on the sticks than others, but even so, they should not be fragile. That is a USA made backhoe, but I think it used an Italian valve. So the "problem" has been rectified on the newer backhoes, but I don't think there is a simple way to retrofit the controls, it would probably take an entire valve assembly and that would be big bucks.
/ Mahindra complaint #14
Backhoe zert fittings that will not take grease usually can be greased by moving the control to get the hoe or stabilizer pin and bushing in a relieved spot. It takes some trial and error to find that sweet spot.
hugs, Brandi
/ Mahindra complaint #15
hugs, Brandi
Or remove the grease zerk, clear out the hole with a small pick (hard or dry grease that looks like dirt is a sure sign of a plugged zerk), and replace the grease zerk.
Many places sell grease zerks for < $1 each.
Good catch on the grease issue ;)
Hope this helps.
- JC
I always have extra zert's on hand, if I'm greasing and there's a problem, I change it right then! I just think this hoe was built as cheap as possible. With some pins, bushings, and different controls I would be happy
I do have welder and wondering where to look for help finding a different control that would be the easiest to adapt to this hoe. Have a great 4th!!!
/ Mahindra complaint #19
I would be extra careful in welding around main support and stess points on the backhoe. New welds should be heat treated to relieve stress cracking.
hugs, Brandi
/ Mahindra complaint #20
hugs, Brandi
- JC
The 1st is usually effective for zerks that have not been neglected. The grease outlet is obstructed by pressure from the pin as Brandi described.
The second fix will have no effect on the 1st condition so be sure its not just blocked before you assume its plugged.
larry
PORTA POTTY (A68842)
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2017 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2017 HINO 268 4X2...
2016 Dodge Grand Caravan (A66738)
2016 Dodge Grand...
FOREDE WATER MIST CANNON (A67714)
FOREDE WATER MIST...
2009 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2009 INTERNATIONAL...
