Kubota drawbar hole diameter??
   / Kubota drawbar hole diameter?? #11
If it were me I'd take a rat-tail file to the drawbar.
Sean
   / Kubota drawbar hole diameter?? #12
A Dremel tool with a round sanding drum, would make short work of the problem also. then put a little grease on the surface with your finger, and put in the ball, and tighten the heck out of the nut and your good to go.:)
Before I got a chance to actually measure the drawbar's hole, my dealer responded to my email about this with: "I don't know why, but it's like a 15/16" hole; kinda dumb. But anyway, I would just use a 7/8" ball and tighten it down good so it doesn't flop around- it should be fine."
   / Kubota drawbar hole diameter?? #14
The hole is probably metric, maybe 24mm. I would take the drawbar to a machine shop and have them drill it out to 33/32 (26mm). Or you could get a Demming bit for your 1/2" drill motor and do it yourself. Then you would be set for any ball or hitch pin 1" or smaller. If you want a smaller pin to fit tightly, just use a bushing.
   / Kubota drawbar hole diameter?? #15
If it is as close as you say...Just a little paint and maybe just a sliver of metal...........GET A BIGGER HAMMER:laughing:
Just gave in & bought another $7 2" ball at HD with a 3/4" shaft. I'll put a bushing in it & be done.
   / Kubota drawbar hole diameter?? #17
Sounds like a plan, assuming of course the bushing fits in the hole...
Hang on to the receipt from HD, you may be back sooner than you thought.
In all seriousness, good luck.. it probably IS metric. I think the one I put in was 7/8 and a little sloppy, but I can't remember for sure.
Sean
Little piece o' PVC, cut to length & sliced on its side to fit, outta do it :thumbsup:
   / Kubota drawbar hole diameter?? #19
Ive seen them with 3/4 and 1" shanks. No 7/8". Anybody?
larry
   / Kubota drawbar hole diameter?? #20
I needed a 2 5/16 ball on mine and they have 1" shafts. I bought a 1" drill bit with a 1/2" shank and put it on my drill press and 15 seconds later the ball fit perfectly.
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
RIGID TOOLBOX (A50854)
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
