Bushhog hookup
/ Bushhog hookup #1
flINTLOCK
PA
NH TC40DA 2002
I've had my tractor and Bushhog for about 3 years now. I use the BH to cut back some trails at hunting camp about once a year, so my experience in hooking up to the tractor is limited. It always seems to be a challenge to get the cutter's shaft collar on the PTO shaft of the tractor. Usually wish that I had 3 hands if I'm doing it alone. Any secrets you guys use would be appreciated.
/ Bushhog hookup #2
It is indeed a hassle, but I've found a few things that help.
1. The more often you do it, the easier it gets.
2. Keep the shaft and the locking mechanism well lubed.
3. It's easier for me to do the pto hookup before the 3pt links. Probably because I'm not as skinny as I once was. :D
/ Bushhog hookup #3
Lube the spline and hook up before the rest of the 3 point. I find the top link gets in my way the most. I also use a string or tie-down to hold the pto shield out of the way. Spin the shaft and try it again if it seems to stick.
/ Bushhog hookup #4
I have tried everything and there is no easy way. My wife and I wrestled around with one and had no luck, so I called my burly son to come up and he wrestled around with and finally for no apparent reason "click" it went right on.
/ Bushhog hookup #5
Does the pto shaft joint have the push button release/lock or the pull back collar type? They present different issues.
larry
/ Bushhog hookup #6
I assume you're talking about a situation where the coupling has worked OK before but now is harder to accomplish the connection. In that case, the secret is to keep the splines clean, clean, clean. Spend a little extra time cleaning the crud out of the splines before you try to attach the pto shaft to the tractor. I've used a dental pick and wire bristle tooth brush to get all the stuff out of the spines.
If it's a new pto shaft that won't slip easily onto the tractor's pto shaft, then you might have to use a flat metal file to dress up the splines before lubricating and trying again. Sometimes there are burrs on the pto coupler left over from manufacturing.
/ Bushhog hookup #7
All good advise here. Keep it cleaned and lubed up and it will make it easier. Other than that I keep all my implements on dollys and on the concrete floor of my pole barn. This way I can back the tractor up within a few feet then get off and roll the implement to the tractor.
The dollys I made are simple using a few 4x4's, some scrap 2x4's, and 4 casters from Harbor Freight. I have about $20 in each and its made life much easier.
Chris
/ Bushhog hookup
The problem I have is getting the collared connector to match up with the splined tractor PTO if the cutter shafts are already telescoped together. It seems easiest to get the tractor connection onto the PTO, then try to get the Cutter shafts to slide together. Would probably be easier if I cut about 1 inch off both parts of the shaft, then after connecting to 3 pt, I could swing the cutter shafts into place while pulling back on the collar and pushing forward with the assembly. The parts are clean and lubed before and after use.
/ Bushhog hookup #9
Don't know if your tractor has a mid/front PTO, but if it does, and if it's like my JD, you can shift the selector into the mid/front setting and it frees up the rear PTO shaft so you can easily turn it to line up the splines.
/ Bushhog hookup #10
Once I get mine lined up it usually goes right on. Sometimes it takes a little persuasion on the U-Joint with a no bounce hammer or rubber mallet. Not too much pressure is needed..
/ Bushhog hookup #11
You have me baffled. Do you split your cutters PTO shaft before connecting it? a Picture would be great.
I have a woods 72" cutter and it's seems to be a breeze to get the pto connected. Mine has the twist collar lock. All I do is put it up to the tractors PTO and is the splines are not lined up I just twist the shaft slowly until they line up then twist the collar open and slide it on and twist the collar to lock.
/ Bushhog hookup #12
Beat me to it... I had the same question. You don't want to separate the pto shaft; it's a stinker to get it back together with both ends hooked up.
Instead, keep the shaft together and just rotate the pto or the collar until the splines line up. Messy, but it should only take a few seconds.
/ Bushhog hookup #13
That'd make it easier for "others" to roll them around ... & out ... too. Depending on how secure your place is.
/ Bushhog hookup #14
I find I can work the PTO into place & secure it ... eventually.
It's the afterwords greasy-hands-and-smelling-like-a-tractor that's annoying.
/ Bushhog hookup #15
If I spent a little time in preparation, cleaning and lubing then I can mine to slip right on. I have the spring button and I almost alway need wd40 and rubber mallet to get it free. Once free, I can get it started and slide it on till it locks into place.
First time I used the BH I didnt realize it needed to slide on and lock. I did manage to finish the job without it coming off thou.:D
Wedge
/ Bushhog hookup #16
... First time I used the BH I didnt realize it needed to slide on and lock.
That's a little scary! Wouldn't that thing flail all around if it came off, until it stopped??
/ Bushhog hookup #17
My Kubota L4400 came with a black plastic tube that fits over the PTO shaft when not in use. This keeps dirt and grit out of the splines and keeps the grease clean. Don't know whether this tube is common on Kubota tractors or not or if it was just a shipping protector. It's handy though and can be easily made.
I store my RC in my shop and tie the PTO shaft out of the way with a supplied chain so it is not near the floor and possible dirt. All this makes for easy hookup.
Chris, your implement dollys are a great idea which I want to build also for my extensive collection of 2 implements! Got any pictures? I'm sure others would be interested too. Mike.
/ Bushhog hookup #18
My Kubota MX5000 came with the same PTO sleeve/cover. I always have it on when the PTO is not in use.
/ Bushhog hookup
Good suggestions. I'll give them a spin. Wish me luck this weekend.
/ Bushhog hookup #20
Here's a way I read on another forum that helped me make the connection easier:
1. WD40 on the pto spline and in the BH connector collar.
2. Hook up both lower links, then raise the BH where the BH shaft is horizontal in line with the pto spline. Then slide the collar onto the pto spline.
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2019 John Deere 4044M (A62177)
2019 John Deere...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
