PTO question
/ PTO question #1
Cub5k
Maryland
Cub 5252
My PTO started acting up today. Seems like after using the PTO (belly mower) for a while and cutting it off it won't turn back on right away. Almost like it has to cool down or something. Usually only takes a minute or so before it will turn back on but I would like to fix it. Any ideas what could cause this?
/ PTO question #2
At the risk of asking the obvious, have you checked to see that the system is filled with the correct fluid?
Has anything changed such as you recently changed the hydro fluid and/or filter? Have you been using the tractor through the winter and the problem has started with the warmer weather?
More details will help.
JN
/ PTO question #3
And....which model do you have? Does it have the reverse override?
/ PTO question
It's a model 5252. Actually this problem occurred a couple times last summer. I use the tractor all year round. I don't know much about the PTO clutches other than they're electrical look to be a bear to replace. This tractor does have the reverse over-ride switch. The PTO switch works perfect unless I have been using the PTO (mower) for an hour or so. Then it will turn off just fine but will not turn back on unless I wait about a minute or two. Sometimes lowering the throttle, engaging the PTO and then giving it full throttle will kick the PTO in. If it was a vacuum operated switch I would say its clogged but this is electrical. It is about 6 years old now so I guess I could be getting a bad ground or loose connection somewhere. Might have to just go connection by connection and clean and tighten as much as possible.
/ PTO question #5
From your reply it sounds that the PTO on your model is electrically engaged. That said, unless the engagement dogs are sticking and resisting movement then your problem must be in the electrical circuit or the engagement solenoid. I would think that there is a way to measure resistance through the energizing circuit and the solenoid itself to troubleshoot the system. While I don't know where you could find it, I think the procedure and values for testing could exist in a service manual for your model.
The starter solenoids on cars can sometimes break down internally and become sensitive to heat in which case it can become necessary to let it cool down before it will energize to start the engine. Perhaps yours is a similar situation.
JN
/ PTO question #6
If the clutch coil was opening up from heat I would expect the PTO to disengage by itself while running. Since you say it only fails to turn back on after prolonged use, I would suspect some kind of mechanical problem such as binding or adjustments. I would check the clutch clearance at several points around the PTO. It may have excessive clearance and engage when cold but fail after running due to more drag when hot or reduced coil pull when hot.
Bob B.
/ PTO question #7
Bob,
I kind of agree with you except that I would guess that more energy (effort) is required to engage the unit than is required to hold it engaged. Is it possible that a weak solenoid can hold the PTO engaged while hot but not have enough to actually initiate engagement? Maybe someone with more practical experience can add to this line of thinking. Thankfully I can say that I have never had an issue with the PTO on my tractor.
JN
/ PTO question #8
Bob,
JN
It definitely takes more power to engage than to hold the clutch engaged but I'm not sure what would cause a "weak" coil other than shorted windings or poor connections, ground or power, causing low voltage. Over the course of 28 years that I had my 1450 I had several occurances where the PTO would not engage initially but once I got it to engage it would work for hours. It was always either too great a clearance between the coil and armature or rusty and sticking armature. I adjusted it to .020' clearnace at 3 points radially and the problem would be solved for a few years.
Bob B.
/ PTO question #9
Bob,
You have had more experience than me and I appreciate the details you gave regarding the adjustment. I'll be squirreling that away as useful information in case I run into issues with my PTO someday. Thanks for that, I may owe you a beer someday! :licking:
JN
/ PTO question
Bob B.
Just got around to adjusting the clutch as you said and it works fine. Thanks!
/ PTO question #11
I love a happy ending. Especially when it involves a tractor. Sounds like Bob deserves a cold one! Cheers! :drink:
JN
/ PTO question #12
Hey Cub5K,
How did you adjust the clutch, I was assuming Bob's suggestion referred to non CUT Cub's that had the PTO mounted on the front of the crank and exposed. Ours is (5252) front and mid and buried in the transaxle?
I did an original post about dash and PTO problems, I was too busy and sent this off to the Cub dealer. They were sure it was a dash that had overheated because of the failed muffler.
I mowed twice after the muffler and dash and loose throttle repair and on the third mowing, took a break, the PTO wouldn't engage. The PTO light was on with the PTO off and the hourmeter was out. I plugged the old dash in and nothing was working, plugged the new one back in, everything is back. I'll call the shop on Monday, but these problems are a nightmare.
I'll post as I make progress.
Curt
/ PTO question
Hey Cub5K,
Curt
The PTO clutch is on top of the transmission housing. You have to remove the seat and fender to get to it but thats only a 10 minute job. There are 3 (or maybe 4??) bolts that adjust the clutch and you use a feeler gauge to set the gap. One of the bolts is on top and easy to get to but the others are down in further. The throttle tension adjustment is under the dash at the bottom of the throttle handle. Just tighten it.
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2011 CATERPILLAR CB24 DOUBLE DRUM ROLLER (A62129)
2011 CATERPILLAR...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
2008 Ford F-150 Ext. Cab Pickup Truck (A61568)
2008 Ford F-150...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
