Cub cadet Mitsubishi 7193 - will not start- it was running parked to install mower deck and the key will not crank the starter.
   / Cub cadet Mitsubishi 7193 - will not start- it was running parked to install mower deck and the key will not crank the starter. #1
nickkreigh
auburn, in
Simplicity
I need some help. I have a cub 7193.545-422D100 model. It was running fine, I parked it in the barn and I went to restart after installing the belly mower. Turned the key all the lights came on, turned the key to start and nothing. Allowed the key to go back to on position and not even the lights were on.
New battery, cleaned terminals, shorted the PTO safety switches and the range select neutral safety switch nothing.
Tried to find a seat safety switch and could not; removed the seat and the panel the seat sets on to find no switch.
I jumped across the starter and it works well.
Any suggestions?
Do you have an electrical schematic and or picture of the harness?
I looked in parts diagrams and the harnesses pictured do not seem to match mine.
   / Cub cadet Mitsubishi 7193 - will not start- it was running parked to install mower deck and the key will not crank the starter. #2
It does indeed sound like a safety switch - or possibly the start switch located in the ignition switch.
Do you know where I could get a wiring schematic?
Is there a seat safety on these?
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A59230)
2017 Autocar...
SKID STEER MOUNTING PLATE (A60430)
SKID STEER...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
