Just about ready to choose
   / Just about ready to choose #11
Between the two tractors go for the one in best condition. They are that close. The smaller and lighter the tractor the more it needs 4wd. Either has ample power.
On the FEL. Definitely get it. Do NOT think you will add it later. Save your back now. That is the implement that these compact tractors were born to use. You won't believe how much you will use the FEL. Get a cheap heavy box blade or angle blade for the back. It's mostly for a counterweight anyway. For pulling it, too small is better than too big. Wire some wire baskets to the top of the blade for carrying tools or extra weight.
good luck, rScotty
   / Just about ready to choose #12
What makes you think a Kubota would last longer than a Yanmar...
I shopped for a used tractor for three years...I researched by watching CL and e-bay...as well as every other online resource...
I also traveled a great deal looking at used machines...almost every Yanmar that I looked at or read about that was over a few years old had been rebuilt or "refurbished"...not the case with Kubota...
   / Just about ready to choose #13
Did you include John Deeres in your comparison? Those would better represent Yanmar-built machines that have aged here in the US alongside the US Kubotas.
It sounds like what you encountered was the Yanmars sold used in Japan, then run to death In Vietnam, and then repainted and shipped over here. While there are a lot of them out there they hardly represent what to expect from a Yanmar (or Deere) that has been in the US since new. (Or one shipped straight from Japan).
If you found a Deere or US Yanmar at the same price as a Kubota I think you would find all three brands are comparable, excellent, quality. Don't let that one market segment, VN 'rebuilts', represent all Yanmars.
   / Just about ready to choose #14
Plan to spend more $$$ on the kubota. It really comes down to each his own.
Same as the old days of comparing ford, to chevy, to mopar.
Both are great long lasting tractors, provided you maintain them and not abuse them. That is the key.
Timely fluid changes, clean fuel, filter changes, and these diesels will run a very long time
   / Just about ready to choose #15
I looked at both...actually I was not even interested in any tractor that had been rebuilt ot refurbished...regardless of where it was done...
As for Deere...I swore off so called "American Companies" that are branded on their historical laurels but produce products made in or from other countries... Milwalkee (sp) tools is the one that broke the camels back for me...20 years ago I spent extra $ to buy a Milwalkee sander (over a Makita) only to find out the Milwakee tool was made elsewhere...
I realize you can't hardly buy anything without buying foriegn parts or products anymore...
   / Just about ready to choose #16
I have an 1820D with the Koyker 80 and find it a very nice combo on my 50 acres. You'll want a 4ft bucket to cover your tire tracks with the 18s.
One thing you should consider is body size and personal comfort. I'm 6'2" tall and 210lbs and the 1820D is a tight fit; about as small a tractor as I'd want to spend much time on, especially in winter with big boots on.
   / Just about ready to choose #17
/pine, what year model is your Kubota? I believe most any 30 year old tractor that has had normal use is going to be approaching a little re-ring, etc. 30 year old tractors can not be expected to be as a new one without a little help. I'm sure there are some out there that had an easy life and truly have low hours, but I don't think it is the norm. At least that is my opinion.
   / Just about ready to choose #18
I just look at it in a different light. If I need a starter or water pump or etc, for my truck, rebuilt is fine with me, I am not concerned that the core(housing) was bolted to something else before. As for the internals such as the armature the shafts have to be within certain specs to be rewound. Take the sheet metal off a tractor and you have a motor block, transmission and axel housing, a core in my eyes, ready for new bearings, sleeves, seals, etc.
Just MHO.
   / Just about ready to choose #19
Whichever one you get, get a FEL!:thumbsup:
   / Just about ready to choose #20
I have 2 acres and I own a 1610D with a FEL. I have owned it for a little over a year now and it has been perfect for my needs. As for the 1810 I've never looked at one but as you say only difference is a little larger size and 2 more HP at the PTO. That's something you'll have to judge as I see it as a toss up. I think either would do well so as the other poster said I would look at which one is in better condition. As to the other question definitely get the FEL. I never have taken mine off and use it all the time. You won't find a more useful implement.
2002 Trotwood Trailer (A50515)
2002 Trotwood...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
