The shaft guard and end shields should never be spinning, they should be tied to keep from spinning. They may wobble but never spin.
I bought it used and part of the plastic shaft guard is gone. Went to my local TSC yesterday to get one and they didn't have one. No vibration after it starts spinning but it thrashes a little bit on engagement.
And important if an attachment that is running off the PTO and someone is working around the PTO shaft.
If the PTO shaft is used, check to be sure it's not bent slightly, it happens more than you might think. Mine got bent a while back and had more run out than it should. You'll have to remove the shaft covers and end guards to check it, I ran mine briefly without them in place to be sure of how much run out there actually was.
I ended up replacing the outer shaft, it was pinned in the universal yoke and could be separated without too much trouble.
Sean
Welder1, just as a mention, when activating the PTO do it slowly but deliberately. This will make things a little easier to start for your tractor as well as the cutter.:thumbsup:
Very important info above. Engaging the PTO at a lower RPM (1200-1500) reduces the shock load on both the tractor and the cutter. Much easier if you have a gear tractor, BTW.
Some hydro machines' PTO is on or off...no feathering as you can do with a gear tractor, unfortunately.
Are you trying to start another gear vs hydro TBN war? Not that I am against it. Always fun reading.
