PTO Shaft Balance
   / PTO Shaft Balance #1
welder1
New tractor owner , operator here. It seems like the pto shaft on my rotary cutter seems to have excessive wobble or runout. Is there a way to get it to run more true or is it not a problem?
   / PTO Shaft Balance #2
At 540 RPM, I don't think balance is a big issue. Plus, you're probably looking at the plastic guard, rather then the shaft.
I've never heard of implements wearing out a tractor PTO by being imbalanced.
So, I suggest you not worry...keep an eye on the implement, not the driveshaft.
   / PTO Shaft Balance #3
Pretty much agree with Roy. Are you getting a lot of vibration?
   / PTO Shaft Balance #4
The shaft guard and end shields should never be spinning, they should be tied to keep from spinning. They may wobble but never spin.
   / PTO Shaft Balance
I bought it used and part of the plastic shaft guard is gone. Went to my local TSC yesterday to get one and they didn't have one. No vibration after it starts spinning but it thrashes a little bit on engagement.
   / PTO Shaft Balance #6
Yeah, but my chain loops went years ago so mine spin (not in sync with the metal drive shaft, but it catches on occasion).
   / PTO Shaft Balance #7
Rotary cutters thrash about a bit until those blades pivot out. As you know, the blades may not be fully extended initially, so the cutter (not the driveshaft) will be out of balance.
Once the blades pivot out (extend), they smooth out considerably...then you can increase the tractor to PTO RPM. I don't think you've a thing to worry about...
   / PTO Shaft Balance #8
And important if an attachment that is running off the PTO and someone is working around the PTO shaft. On a rotary cutter, not of significance, as no one would be running a RC with someone near it on the ground (unless of course one carries riders along on the deck :) NOT! )
   / PTO Shaft Balance #9
I agree with Roy about the low rpm not causing a vibration problem.
The cutters on my LX4 are weird. They seem to very seldom fully extend and flop in unison. So, the thing ends up very slightly out of balance until I hit something solid enough to jolt them into swinging right. I've lubed them with silicone spray to no avail. They just do their thing. SOMETIMES engaging and disengaging at different rpm straightens them out but not always. When they're swinging nicely in unison, the cutter is virtually as smooth as a straight blade lawnmower, but this often doesn't last long.
Ralph
   / PTO Shaft Balance #10
Nobody works around my drive shaft when it's running, including me. My only stationary implement is a chipper and we always approach from the rear.
Even when I have to get near the tractor, I give it wide berth (8-10 feet). With my bad leg, I trip or stumble occasionaly anyway...and I'm not going to be near any rotating equipment if and when I do.
KMC 3376 LOT NUMBER 271 (A53084)
KMC 3376 LOT...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
