Clearing brush or blowdowns
/ Clearing brush or blowdowns #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
I was wondering whats out there, available to cut alder trees maybe 1.5 inch in diameter or maybe younger trees or spruce samiplings 6 ft in height. has anyone made such an outfit, if so whats required. What available ont he markets for this and how much would one cost. I was wondering if i could set it up on a J5 bombardier tractor. Thanks.
/ Clearing brush or blowdowns #2
This is what I would use.
the yellow one looks interesting. (laughing), yeah i have a few huskies..but i was looking for something I can drive for miles on end to clear the brush growing in on a road we use for a cabin. If there is something available that is.
/ Clearing brush or blowdowns #4
1.5"? Sheesh, that's brush hog material. Anything, especially soft alder, less than the thickness of your wrist is easily mowed with a brush hog. Rotary cutter is the proper name for the very common mower deck.
/ Clearing brush or blowdowns #5
They make attachments for skid-steers and excavators that are somewhat similar to a flail mowers except they can chew up stumps and brush. If you have several acres one of those machine will take care of it in a couple of days. How about cut it with your chainsaw and get a wood chipper.
I think this is what you need.
www.youtube.com/watch?v=hOWGG4Bvz0Q&feature=related
/ Clearing brush or blowdowns #6
What about the stubs? Wouldn't a mulcher work better?
/ Clearing brush or blowdowns #7
Doesn't say where you are located but if you want to drive over it with a rubber tired vehicle you probably need to find somebody with a mulcher in your area who can do it fo you.
Terex-ASV PT-100 Forestry with ASV Mulcher, by Fecon
/ Clearing brush or blowdowns #8
I think a root grapple would work pretty good on them. Your bucket with a tooth bar should also work.
First, push the saplings over, then back up and lower the grapple/bucket into the partially pushed over root ball and push the trees out. A grapple is good since the dirt will fall through, but a bucket will do the job, too.
Here's a pic of my grapple...
/ Clearing brush or blowdowns #9
Aww guys, you make me envious with the mulcher videos, LOL. Unfortunately, I know those rigs are expensive :(
To the OP, you could rent one and do the initial clearing. Our local Bobcat dealer rents the entire setup (CTL and mulcher) for $2000/wk. Once you have it cleared, you can maintain it with a tractor and rotary cutter ("bush hog") easily.
I don't know if the $2K is a good price, or if you could get someone with the equipment in to do it on a one time basis for a lower amount.
Ken
/ Clearing brush or blowdowns #11
If it is going to be a roadway, the less the soil is disturbed, the better. A lot of digging to remove the roots will leave soft spots unless you are going to fill and compact the roadway.
Ken
/ Clearing brush or blowdowns #12
How about something like this.
/ Clearing brush or blowdowns #13
Loader buddy looks good. Pallet forks might also be used to pop the trees out, but would be slow going.
/ Clearing brush or blowdowns #14
The first two are probably overkill for the small saplings and would probably leave sharp stubs. The third and fourth may work well but he is going to have a large brush pile to dispose of. That's the advantage of a rotary mower or a mulcher, they chop up what they cut.
Ken
/ Clearing brush or blowdowns #15
For the OP's task, a rotary cutter (brush hog if you will) would easily do the job. Handy to have a FEL with bucket or forks or tines to move large objects (fallen trees, or boulders) to the side as well. But to me, it would clearly be just rotary cutter work ($1-1.5k).
(if the tractor will handle a rotary cutter a bit wider than the rear wheels, and if 3 ph with PTO are available on the J5 bombardier tractor)
Anything else, more expensive and/or more tractor seat time. :D
/ Clearing brush or blowdowns #16
Brush hog, if the terrain is level enough. You might have to use a chain saw on the bigger stuff, but once you get it done the secret is to maintain it every year or two. It gets easier each time.....
I made a small side mounted hog out of an old 3' mower deck with longer blades so it cuts 4' swath out behind the right rear wheel. Dangerous as heck, but I don't run it when there are bystanders. Biggest problem is keeping the soft steel blades sharp with all the rocks.
/ Clearing brush or blowdowns #17
HAving used the asv 100 with a forestry package If I had any amount of this type work to do I would hands down go with a rental. They make short work of this type of project. I cut several propertys over one summer laying out 4 wheeler trails and drives. I can say we charged 100.00 an hour with a 10 hr minimum. I never spent more that 20 hrs on any of the propertys and was done.
My rentals ran me 700 a week but in the end we had it for almost 2 months and ended up getting it cheaper because of a month price.
There are definately cheaper ways to do it. If I had a smaller amount to do no way would I lay out 700.00 but cutting a mile and a half road through the woods,,,, it is a no brainer.
/ Clearing brush or blowdowns #18
From what I can find out the J5 doesnt have PTO. Does it have hyd output of near 20gpm to drive a mower hydraulically? ... Doesnt seem the ideal setup. ... A decent bushog on a 45pto hp tractor would run thru what youre talking about at 4mph and leave a near clear path. Using nice dull blades at 1mph at scalp level would cut, loosen, and frazzle the stumps leaving a clear tire safe path in one pass.
larry
Has anyone ever made a homemade version? What speed is that rotating, how much torque or flow rate does something like that mulching head have? How much would an attactment like that cost?
/ Clearing brush or blowdowns #20
You could use one of the small stump grinder heads with a hyd motor and get the job done.
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A64556)
2015 Ford F-450...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
KUBOTA 4 BASKET HAY TEDDER (A64278)
KUBOTA 4 BASKET...
2006 Toyota Highlander Hybrid SUV (A64557)
2006 Toyota...
2000 INTERNATIONAL 4900 - 10 WHEELER GRAIN TRUCK (A64278)
2000 INTERNATIONAL...
