I think I am going to get bit!
   / I think I am going to get bit! #1
BryanM
Gold Member
Northwest Ohio
John deere 2155, ford 1600
I think I am going to get bite!
Well had a window of 4 days to hay and tried to get it done baled a few bales and tested moisture with a farmex moisture tester. It looked good except had pockets in the bale where it was a bit wet. These pockets where reading around 20 to 26% moisture. So I broke the bales open and spread them out. And of course the weather has rain in the forcast.
Should I leave the hay in rows or spread out? It feels almost dry except for a few spots low in the rows?
   / I think I am going to get bit! #2
Re: I think I am going to get bite!
What are you using for a rake? If it is a roll bar rake I would spread them out. If it is a rotary I would leave them. The rotary make a row that will allow better air flow, where a roll bar ropes the hay in a tighter row.
With 4 days, what is your mower, does it have a conditioner?
Did you get your tedder issue resolved?
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2012 Peterbilt 389 Semi (A59814)
2012 Peterbilt 389...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
