I Know, I know ....
   / I Know, I know ....
Instead of windrow testing why don't you roll one and probe the bale right after it comes out of the roller, I'm not trying to be a know it all , just curious.
Hadn't considered that, no reason not to. Although many on here, far more experienced at this than me will just say 'stop worrying!' And they're probably right!
   / I Know, I know .... #13
That's how I have always done it, I actually thought that if a moisture probe was used that's how everyone did it. If it reads higher than I like I just wait an hour and try another one, sometimes that's all it takes, if I know rain is coming I might push it a little but my preference is to roll between 10-14%
   / I Know, I know .... #14
Common around here, VT. Is to leave the fresh gatherd bales on the wagon for the first night.
   / I Know, I know .... #15
I just baled hay that was laying in a field for get this….9 days….
It was never rained on. I just couldn’t get to it. I baled it yesterday expecting crap hay and it was still beautiful green underneath, but perfectly dry. It’s about 65% green and 35% “tan” where facing the sun. Bales have surprisingly good color and moisture is about 8%.
Conversely, I made bales waiting the typical 3 days, and most turned to junk…moisture was ~20%.
Learning when to cut and when to bale is the art of baling. Knowing patience and weather and when it’s just right is the whole art of making the best hay. Also accepting that as your climate goes through daily changes has tremendous impact on your hays’ quality.
A guy over the way cut and windrowed a couple of weeks back but got caught by a couple of storms and now, although beautiful weather for over a week now, the morning heavy dew doesn't burn off 'til late morn/lunchtime then evening dew starts settling 6-7pm. He came by a couple of days ago and just tedded it out and abandoned it. I ecided last year that I wasn't doing a final cut as it's always a challenge to dry here this time of year with the heavy dew. Maybe I'm just in a peculiar area (edge of several thousand acres of forest and a big river a few hundred yards away)
   / I Know, I know .... #17
It’s very hard to get hay dry where I am, in the central upper penninsula of Michigan. I struggled for my first couple years making hay to actually get a window where I can get it dry enough to bale. I’m doing two things differently this year that are really helping. First, I am following “pan evaporation“, and my reading says that you should have a total pan evaporation of 0.6 inches to get hay dry. This seems to be pretty accurate. That assumes you spread your hay wide or you ted it right after you cut it. I do both. Mostly grass. The second thing which has made a huge difference is that I put an acid preservative system on my baler last year. It makes a huge difference. I can bale at 25% moisture and not have mold or dust. Of course, I have to be spraying the right amount of chemical. I carry a moisture meter in my cab and check the first three bales that come out and then every 30 or 40 there after and adjust the spray. I’ve been absolutely amazed at how well it works. I am feeding out some of my first cutting that I baled at 25% and it definitely feels a little moist - more soft than anything, but zero dust and zero mold. I think for anyone who has trouble getting hay dry due to their climate ought to at least consider a preservative system. I did not go with the fancy one – just the manual dial control that adjust the pressure on the sprayer. Super simple, super reliable, it just works.
TUGGER TRAILER (A58214)
TUGGER TRAILER...
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota M5-111 (A53317)
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2012 ADDCO S/A Towable Arrow Board (A55973)
2012 ADDCO S/A...
