Incline Education Requested
/ Incline Education Requested #1
Mcduck
Hi guys, I have just ordered a 23 hp craftsman lawn tractor. Appears to be just what I need for my oversized backyard. Now I am getting second thoughts about completing the deal. The issue is I have a slope in my backyardwhich appears to be 15 to 20 degrees. In order to cut the slope I need to traverse it which the Sears manual says is a no no. I weigh 200 lbs and figure if I keep my speed down and offset my weight it should be no problem. How tippy are these things? Am I asking for trouble. Your experience would be appreciated!!
Thanks
McDuck
/ Incline Education Requested #2
Can't say anything about the Craftsman mower specifically, but any slope mowing "sideways" is likely asking for trouble and generally to be avoided. Guess you won't know til you try it, but I'd be darned careful! Perhaps it would be worthwhile to use a small push mower for the slope?
/ Incline Education Requested #3
"offset my weight it should be no problem"
That might work if there isn't some sort safety switch in seat.
Go slow on each pass until your gut feeling says enough.
Thanks for info and opinions.
/ Incline Education Requested #5
Thanks
McDuck
I have an 18HP Craftsman and weigh 200 lbs. I also have a 15 degree slope and a 20 degree slope. I've been mowing (slowly) the 15 degree slope for 10 years without any problems. However, I wont traverse the 20 degree slope, do that one with walk behind. Suggest you determine the actual slope degrees then follow the mower's manual.
/ Incline Education Requested #6
Look at Power Trac tractors. Rated for i believe 30 - 45 degrees depending upon the model. I have the 45 degree model.
Ken
2011 INTERNATIONAL 4400 (A60736)
2011 INTERNATIONAL...
2020 MACK P164T (A58214)
2020 MACK P164T...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2022 SANY SY35U EXCAVATOR (A59823)
2022 SANY SY35U...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
