hunterridgefarm
- Joined
- Jul 12, 2005
- Messages
- 2,131
- Location
- Western NC
- Tractor
- Kubota L3130DT, Kubota L185DT, JD LX277
I needed to add nitrogen to my 4 acre bottom that I plant. I planted around 3 acres last September and till about a 3/4 acre in Feb to plant potatoes and onions. A couple of weeks later till a little more for veggies and such. Well time got away from me and the rye was 6' tall a few weeks back. I re-tilled the section for veggies last week so to plant this Saturday. I knew better, but, I tried to run the 5' tiller through the 6' rye. One pass and the tiller was full of rye.
I had to bush hog some lots this Saturday so since the bush hog was on the tractor I dicided to mow down the rye. Chopped the rye good except where the tractor tire just laid it over. So tilling is not an option. I need to plow or disc first. The whole point of buying the tiller was to get out of plowing and this is the first time I have planted rye. It has rained today so the ground will be soft enough to disc tomorrow. The disc should chop the rye up enougn to allow me to till.
I need to get the rye tilled in since I will be planting watermellon and cantaloupe in about two weeks. Pumpkins will go in the 1st or second week of June.
To get to the point of this thread. How many of you plant rye for a green manure and when do you till it in? A foot or two tall seems to work good with the tiller... but 6'
Thanks
David
Next year if this happens I will cut and bale!
Thanks
David
