HST Fan on GC
/ HST Fan on GC #1
6dog
Ellicott City, MD
2003 JD 4110 w/ Curtis Cab
Has anyone had a problem with the hydro fan on their GC (busted blades)? I have seen quite a few examples on the Kubota forum, but haven't seen much on here about it.
/ HST Fan on GC #2
some here have broken blades off there fans as well.I haven't yet and doubt if I will as I have a solution.Any time I take mine into the rough I put my homemade skid plate and fan guard on.:thumbsup:Larry
/ HST Fan on GC
Looks nice Larry. :thumbsup: I'm going to assume it doesn't work with the deck on, does it?
/ HST Fan on GC #4
I've never thougth to try it to see if it would fit with the deck on.The other thing is that if the deck is on then chances of anything getting up into the fan are are pretty slim. Larry
/ HST Fan on GC
I was curious if you could just leave it up there, instead of swapping it out each time. :)
/ HST Fan on GC #6
To take it off and put it on takes maybe 5 minutes.I know it doesn;t take very long at all to do.I leave the hydro oil filter guard on always and the fan guard bolts to it with 3 bolts so its simple to take off and on.The skid plate under the rear diff is held on with 2 bolts thru the rear hitch support and 2 bolts into the oil filter guard it doesn't take very long to put on and take off either.I don't like leaving it on as it will collect grass and stuff so I take it off as well.Larry
/ HST Fan on GC #7
I've replaced 2 in 6 years...if a stick is really determined it will find it's wat in there...the fans are pretty cheap and it only takes about 20 minutes to change. You can do everything from under the tractor...loosen the driveshaft yoke pinch bolt, slide toward front of tractor...remove 2 bolts on fan and discard...lather ,rinse, repeat. HST Fan Part No. 4264911M1 is available at Jack's Small Engines for $18.33 net. Jackssmallengines.com 1-877-737-2787.
/ HST Fan on GC
Thanks for the info. :thumbsup: Sounds like not too big of a deal if it happens to break. I would still prefer a radiator-mounted cooler though. :rolleyes:
/ HST Fan on GC #9
Could be worse..like the BX. Having to remove the engine:shocked:!
/ HST Fan on GC #10
Putting my mower on for my first mow of the season, found 3 blades broke. I was using my brush mower last week, so maybe that did it. Was going to mow anyway, but decided not to risk over heating the HST. Does not look too bad to replace, but an inconvenience for sure.... :(
Hope Massey is not too much more cash than the mentioned Jack's small engine, I live in Canada and not sure if Jack would mail one up north.
/ HST Fan on GC #11
Well, I am not sure if it is because I have a 2310 with the sub frame, but what a
@$@#$!#% pain that was to change the fan. I just could not get it on the shaft ( without fear of snapping a blade ) without pretty much taking off the
floor board. Then once i got it on, the engine to HST shaft fell off the u-joint off the engine. You cannot see it, nor reach it very well to feed the shaft back on, as the underside has the metal skid plate. But, after a lot of scrapes and swearing pretty loud, it is done. I am building a shield for this stupidly designed fan ! :confused2:
/ HST Fan on GC
Just keep working in the woods without the deck and you will get plenty of practice at it. :laughing:
/ HST Fan on GC #13
Just remember....It could always be worse:)
CASE INTERNATIONAL 39 DISC HARROW (A64278)
CASE INTERNATIONAL...
2022 EZ-GO ELITE...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
2022 EZ-GO ELITE...
