homebuilt backhoe
/ homebuilt backhoe
Well Long Time no post,
Anyway still havent got any pictures yet.
but so far i have basicly (besides alittle welding) finshed the boom and stick and the engine and tank mount are done, joysticks are mounted and seat are mounted.
and today i got the hydrulic pump and pump to engine coupler, i ended up getting a 6 GPM pump, i was just going to get the 3 like most people suggested but then i desieded that i was going to make a brush mower for it so i went with the 6 insted of the 3
My question is what size hose should i use.
Thanks
Reid
/ homebuilt backhoe #63
Nice job on the hoe, what is the measurements on the dipper arm, from the pivot pin to the end of the arm where the dipper cylinder pins on. am building one alittle bigger then yours, was just wondering, Thanks
/ homebuilt backhoe
i will get some measurements in a few days
/ homebuilt backhoe
Hey,
Here are some pic's!!
/ homebuilt backhoe #66
Today I checked hose sizes on the TSC wood spliters. Not sure about pump size but had a 6 HP engine and 1/2 and 3/4 ID hoses so that I am guessing that is an overkill but over is better than under. :)
/ homebuilt backhoe #67
1/2 or 1/4 should work fine. Even at 6 gpm you'll not have huge flow rates, and in some cases you'll want to reduce the flow rate, I'd think 1/4 would be fine, I'd use whichever you can get at less money.
Joel
/ homebuilt backhoe
Joel
ok thanks,
I will take this in to acount when i go to buy the hoses.
another thing whats the best way to measure for the hoses, i was just going to use some rope.
thanks
/ homebuilt backhoe
Well here's some new picture's
for the door I Made a frame out of 1" square tubing and then used a old fradge rake for the top and toke some 10ga sheet.
havent made hinges yet tho
/ homebuilt backhoe #70
That screen should keep the squirrels from burning their lips on the exhaust pipe for sure.
/ homebuilt backhoe #74
Hey Reid, it's looking better all the time. I was just out in BC last week, I kept looking for your BH but no luck:D
Keep em coming.
/ homebuilt backhoe
Keep em coming.
Cool,
Well its under lock and key (A BIG lock) :laughing:
/ homebuilt backhoe
Well just another progress report.
I Have omost finshed the engine Bay and u have made some costum joystick handles, and also lat but not least A Thumb:D.
Here are some pics hope you injoy
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
2024 CATERPILLAR 299D3 XE SKID STEER (A65053)
2024 CATERPILLAR...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2022 EZ-GO ELITE...
2019 FREIGHTLINER CASCADIA TRUCK TRACTOR (A67148)
2019 FREIGHTLINER...
