Grading Scraper blade - how wide?
/ Scraper blade - how wide? #1
Canuck_49
Member
Tallahassee, FL
Branson 3510i
Hey Guys - I'm shopping for a scraper blade for my 3510i and was wondering what width you guys were using.
I'd like to get a 7' but don't want to overload the tractor. Would a 6' be a better choice?
/ Scraper blade - how wide? #3
I've got the Landpride RB3584 (84") blade for my 3510h. Using it mainly to maintain a 1400' gravel drive, I have no problem with power. A six foot blade won't cover your tracks when angled. Hope this helps.
Mark
Thanks Guys; helpful info as always on this board and it's appreciated.
Hopefully I'll soon be able to contribute too!
Canuck
/ Scraper blade - how wide? #5
Just wondering since I have been thinking of getting a rear blade also...my tractor is 6 feet wide.
I was thinking about a 7 foot blade. Do you guys that have 7 foot blades...do they cover a 6 foot width at 45 degrees? Or would it be an 8 footer at 45 degrees to cover a 6 foot width? Opinions?
/ Scraper blade - how wide? #7
I think it de[pends upon what your attempting to move with the blade.
If I liked plowing snow with a rear blade, I'd look at an 8 footer. If I intended to do much dirt work, a 7 footer. depends upon HP and weight of the tractor too...
Not much snow to move in Florida. :laughing:
I 'm about 1/2 mile off the pavement so would be helping my neighbors maintain the dirt road. Plus my lane is about 500 ft. long as well.
Sounds like a 7 footer is the way to go.
/ Scraper blade - how wide? #10
Just thinking about a scraper blade some more...you could put it up front with a 3 point attachment plate, (rotate it around 180 degrees and angle it). Then have more control using the blade...curl, etc.
http://www.tractorbynet.com/forums/customization/142456-3-point-hitch-loader-arms.html
Hmmm...
Strictly an uneducated opinion here, but I would think that may put alot of stress on the loader arms. Might be O.K. with snow, but I would hestitate before I used it like a dozer blade in the dirt.
Mark
/ Scraper blade - how wide? #11
Mark
Ditto.
If I did it, it would certainly have skid shoes on it, and only for snow...At a high angle, in dirt, I think you could really tweak the arms if you were daydreamin'...
/ Scraper blade - how wide? #12
Yes, I was thinking of using it for just light scraping. If you want to move dirt, the box blade is the thing.
/ Scraper blade - how wide? #13
A 7 footer will not cover your tracks when angled 45 degrees.
/ Scraper blade - how wide? #14
Even though I have not specifically measured the angle that I keep my RB3584 blade set at when I grade my drive, it seems to cover the tracks of my 3510 just fine. Could be that it is somewhat under 45 degrees, but seems to do the job just fine.
Mark
/ Scraper blade - how wide? #15
Mark
And this would be different from plowing how?
/ Scraper blade - how wide? #16
Mark
I never said that a 7 foot blade would not work. In fact I would think that it would work quite well. Myself, I usually set my rear blade between 30 & 40 degrees. Very very seldom do I put it all the way to 45 degrees. I was only answering a question about if a 7 foot blade on a 45 degree angle would cover a 6 foot wide track. No, it will not. ;)
/ Scraper blade - how wide? #17
I never said that a 7 foot blade would not work. In fact I would think that it would work quite well. Myself, I usually set my rear blade between 30 & 40 degrees. Very very seldom do I put it all the way to 45 degrees. [I was only answering a question about if a 7 foot blade on a 45 degree angle would cover a 6 foot wide track. No, it will not.] ;)
Correct. It will cover 7/root2= 7/1.414 = 4.95 feet.
larry
/ Scraper blade - how wide? #18
Like I said, "might be O.K. in the snow".
What kind of plowing were you talkin' about. Or were you asking the difference between plowing snow and dozing dirt?
/ Scraper blade - how wide? #19
Sorry, I thought you were answering the OP's question. I see now that you were answering Redbug's question in another post. Should have payed closer attention.
Mark
/ Scraper blade - how wide? #20
I have a 6' or 7' (I forget) scrapper blade that I got with a 8N Ford I bought 10 years ago. I graded a lot of dirt with it with the 8N.
Since I bought my 3510 5 years ago I have never used the blade. I did buy a 5' Box Blade and it is much easier to use than the scrapper blade. The box blade has double blades and will push forward or reverse. It also has the teeth for serious work. If I angle it right it skids and levels great.
You might want to re-think your choice of implements.
My neighbor had 8 loads of dirt delivered. A friend of his has a tractor. I told my neighbor if his friend wants to grade the dirt he better ride with the dump truck driver to beat me to it!! ;)
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A67148)
2015 FREIGHTLINER...
2022 EZ-GO ELITE...
2019 CATERPILLAR 299D3 XE SKID STEER (A65053)
2019 CATERPILLAR...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
