Tilt-bed or Straight
/ Tilt-bed or Straight #1
Lunk
WI
Branson 4720H / BL200 Loader
Buying a new trailer.
I've gotten prices on a pair of 20', 5 ton tandem axle utility trailers.
One is a hydraulic tilt-bed (manual pump), and the other is a standard 5 ton channel frame non-tilting, with 4' fold up knee ramps.
Prices are actually within a couple hundred bucks.
Any preferences?
Thanks,
Lunk
/ Tilt-bed or Straight #2
Any preferences?
Thanks,
Lunk
I'm also looking for this type of trailer. Haven't found what I want yet.
One possible problem with tilt beds is the location of the axles--not far enough to the rear so it could be a problem to balance the load and get the correct tongue weight. I also understand that tilt beds might be a bit more prone to fishtailing than the non-tilt, also because of axle location.
That said, tilt beds are attractive to old guys like me--don't have to mess with ramps. I collect and restore old tractors so the tilt bed is nice for handling tricycle-type tractors. You need a third ramp to handle this type with a non-tilt.
/ Tilt-bed or Straight #3
If your willing to spend a couple dollars more go with the tiltable one. However, the type of lift used is something to pay attention to. A single cylinder mounted to the center of the bed could lead to problems, depending on how it's affixed.
/ Tilt-bed or Straight #4
I have an H&H 9900# tilt. I converted it to an electric/hydraulic tilt and added a winch. Without the winch it is dangerous to load a tractor alone because you have to drive it on and lock the brakes and get off and lower it. You can also get a wireless remote control for the tilt which makes it alot safer. I have the wood floor. Think of the last few feet of the trailer as just a ramp and load accordingly, there will be no sway.
H&H Trailers < Video Playlist | Embedr
If you haul multiple vehicles it is a pain because you have to load one, lower the trailer, chain it, raise the trailer and load another and repeat. That said, for the way I use mine I would not be without it.
/ Tilt-bed or Straight #5
One issue I have with tilts is axle location. Good pulling trailers have the center of the axles set back 65% of the length of the trailer. Most tilts are forward of that. The other issue is loading multiple objects. A tilt would not work for me very well but I guess I could get around it. Say I wanted my tiller on the front the load the tractor. The tiller would slide. Another issue is most tilts have metal decks. Very slick in the rain or snow. I could not imagine loading my tractor when doing snow removal with a slick metal deck. I like wood.
As for loading tri-cycle gear tractors I do it all the time with only two ramps. I back on the mains at a slight angle then bring the fronts over to the right or left ramp. I do not move the ramps, just do it all in one fail sweep. Done it many of times with a Ford 961 and a John Deere A.
Chris
/ Tilt-bed or Straight #6
Chris
Never thought of doing it that way--probably won't try it myself considering my skill level compared to yours since just my luck I'll have a bad day and dump the tractor and myself off the trailer.
Pricing is about even.
The non-tilt one is built a bit heavier.
I've no problem handling ramps (yet:)), so I'll probably go with a non tilting unit.
Thanks to those who responded.
Lunk
/ Tilt-bed or Straight #8
Not skill, just dumb. As I get older I seem to think things out a little more then do it . As you know when you are young you do then think "man I was lucky that did not kill me". Really though I seen it done many times at tractor shows and such by old-timer's so I guess its a standard practice around here.
I feel more secure doing this than driving a old tri-cycle machine up front first. Its always going on backwards first if I am in the seat.
Chris
/ Tilt-bed or Straight #9
Lunk, late responder, but I have a bumper pull, 10,000# 16' flatbed, wood deck, 5' slide out ramps. Having learned a few lessons, my dream trailer:
Wood deck.
22~24'.
12-14,000 # gvw.
Bed over.
Tilt up dove tail.
Likely flip up ramps (still working on the best answer -- but longer than 5').
Sideboard pockets.
Plenty of tie downs, wrapping rail around the pockets.
Bumper pull.
Sealed or LED tail lights
Back up lights.
/ Tilt-bed or Straight #10
Chris
I do all most the same thing but I drive, works better when you have an attachment on the 3 point.
/ Tilt-bed or Straight #11
I have an Econoline 7 Ton Deck-over with a single cylinder that acts as a shock to slow the tilt action of the trailer bed. Works perfect! FAST, easy and safe loading and unloading. The deck starts to tilt when the load CG cross-over the tilt pivot. So, I know when I am starting to apply tongue weight. It helps me to determine how much tongue weight I have for that load. Being a tag-along, I can put any loose items in the bed of the truck.
I would not want a hydraulic tilt, unless I could use it for both a hydraulic tilt and bypass so the cylinder acts like a shock absorber.
/ Tilt-bed or Straight #12
Lunk,
One other thing not mentioned to consider is the payload capacity of the two trailers. You mentioned the tilt trailer is built heavier and if both are rated for 10,000 lbs the non tilt will have a substancially higher payload capacity. Check the weights out before you buy.
I would recomend a 12,000 or 14,000 non tilt trailer as the cost is only a few hundred more the weight is only a few hundred more and results in a much higher payload. If you need to move a larger tractor in the future you will be good to go.
2018 Ford Escape SUV (A61574)
2018 Ford Escape...
2001 FORD F-150 LARIAT TRUCK (A64276)
2001 FORD F-150...
2003 HRTO 14ft. Enclosed S/A Trailer (A61574)
2003 HRTO 14ft...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
