3-Point Hitch 2305 Lubrication
/ 2305 Lubrication #1
Twogreens
Upstate central NY
Hi everyone. I am new to this website but have been reading everyones input for a few months. I have 10 hours on my 2305 and gone through the manual to do the proper maintenance. Since I am not a mechanic, I have a question that seems probably dumb to most of you, how do you lube the ball joints on the 3 point hitch? (Since there are no fittings) :(
/ 2305 Lubrication #2
I have a 2320 and have never put anything on the ball joints, but they are still moving freely. but i bet it wouldnt hurt to lube them every now and then..
If they ever needed lubing, I would NOT put anything that would attract dirt on them (ie grease).. If they dont move freely i would find a spray lubricant and use that..
Brian
/ 2305 Lubrication #3
I used to spray mine with an aerosol dry lubricant (actually white grease).
Since I installed Pat's Easy Change several years ago, I hit those joints with WD-40 (remove any water/condensation) then both the joints and the easy change with the white grease spray described above.
/ 2305 Lubrication #4
Fluid Film is by far the best for those, and all of the linkages IMHO. Since it has no solvents that evaporate, it outlasts anything else. Most JD dealers sell it.
/ 2305 Lubrication #6
Thanks for that tip, Kennyd!!!
/ 2305 Lubrication
Thanks everyone for your quick and helpful responses.
Any idea why JD tells you to lube the ball joints in the operators manual?
/ 2305 Lubrication #10
I think im am have a destiny to buy some Fluid Film - over on another forum it came highly recommended as a lubricant for a .22 conversion for the ar15. I had never heard of it before, but will add it to my shopping list, especially since I now have 2 uses for it..
Brian
Komatsu D61PX (A64126)
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2022 EZ-GO ELITE...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
