Pat's Quick Change question
/ Pat's Quick Change question #41
Do you have to do any adjustments to it between the 3 implements that you use with it? Do you just back up to any/all of the 3, raise it up and drive off? I'm trying to understand it better since I've had/have the other 3 but haven't tried this one. Why won't you tell the price?
Theyre around $200+. Fixed width may not agree w all implements. You can get a chinese copy for $70 @ HF on sale.
larry
/ Pat's Quick Change question #42
Here are pictures of the $70 ones hooked up to my boxblade upside down to see if they will work OK upside down. Maybe they're not upside down and are supposed to be this way,:) they don't come with instructions. I could have put them up but would have had to lift boxblade up to them or lifted boxblade with fel and put blocks under the front of it then come under the bb pins. Really tested these with some extreme rock digging and had no issues. Subsurface rocks stopped tractor and big rocks gave up their grip and rolled out of the way. I feel confident of the strength of these now that I have tested them at the extreme.
They slip off and on in less than a minute.
/ Pat's Quick Change question #43
Sorry didn't realize I had not mentioned price. The landpride is $400 up here in the frozen north, they will be cheaper by allot down your area. There are real nice knockoffs that are identical to the Landpride for about $200. There are really cheap ones for under $100. I looked at all of them and decided the LP was worth the extra $$.:) As for the width of the hooks I have not come across anything that would not work. They will come off in a jiffy if need be. I will post a pic of mine on the tractor when I get my camera back.
/ Pat's Quick Change question #44
I'd say Landpride is about the same price anywhere and if $400 is the going price then that will be the reason they don't have alot of support from buyers. A $70 one was mentioned at HF, does anyone have one from HF? Or the $70 one? Not sure I understand how the top arm works, hooks up on all implements. Can someone please provide pictures and input on the upper arm connections on different implements with one of these fixed ones that you don't have to get off of the tractor to hook up, except for drive shaft implements?
/ Pat's Quick Change question #45
Hummm...I am confused as to the confusion. The top center link is a large hook that hooks onto the center link pin of the implement. The center link pin is left permanently in the implement. You back the tractor with QH up to the implement, lined up on the pins and then lift up the QH. The center hook hooks onto the center link pin of the implement and the lower hooks grab the main lift pins on the implement and everything is locked in place with spring loaded locks.
/ Pat's Quick Change question #46
/ Pat's Quick Change question #47
My confusion is that it's being implied/stated here that with one of these fixed QH's that one buys it, attaches it and from then on you don't get off the tractor any more except to hook up a drive shaft. Now over the years when I study these fixed QH's there are some people that have bought them they are saying that they don't fit all implements and that the upper arm has to be modified or some type of attachment has to be added. All I'm asking is a picture of your implements attached to this QH and do all of your implements work on it with a simple back up, raise arms and drive off. If you'll provide that info and your pictures even someone as thick as me can possibly get over my confusion. Post the pictures and tell the/your implements. Please help me!!! I read the posts SPYDERLK referenced and became more confused about how universal and simple these work. I hate to have to go and spend $80 to $100 to find out how these really work and are they truly universal and will work on all of my implements.:confused::confused::confused:
/ Pat's Quick Change question #48
Pic will come. As for modifying the only top like I had to modify was on my 3pt estate sprayer because of the design of it I had to make a little bracket to move it out a few inches so the top hook could get under it. Other than that my 3pt fert. spreader, rototiller work great. Hook up is no effort. I don't have a box blade, cultivator or anything like that but I have looked at them and they all would work great. The only thing is it must be a cat. 1 hitch not cat.0.
Cat. 0 has narrower spread on the main links.
/ Pat's Quick Change question #49
John I hear you. I finally went with Pat's solution but they are still in the box since we worked (messed with) on the JD BH for 11 hours yesterday but we got serious leaks stopped on each end and installed a new alternator on it and a lot of cleaning. Just could not stand to replace the alternator with that dirt being trapped behind it so we spent a lot of time cleaning first. :) Hey it looked great in the sun light this morning.
All QH's seem to be a trade off at some level. It seems like they may work just fine for most pieces of equipment but not everything one may have.
/ Pat's Quick Change question #50
OK, got the PATS, now my hydraulic top link is too short. Who offers a top link extender? I have seen some custom made, but where can you buy one?
/ Pat's Quick Change question #51
TSC has longer adjustable arms for around $20. That's for regular upper arm. Don't know about hydraulic link. Well, as I've found out some of my prices are a bit out dated but that's what I paid for mine a few years ago. JD was my first stop and they wanted $90 for theirs so one of the few times I was happy with my TSC transaction. If you have implements with drive shafts then you'll have to deal with that, maybe. Think there are extenders for around $20. Maybe your drive shafts will be long enough.
/ Pat's Quick Change question #52
Guess you still have to get off to hook up drive shaft on tiller. Was your tiller drive shaft long enough or did you have to do some thing to/about it?
/ Pat's Quick Change question #53
Oh. Sorry that link didnt present clarity. Try this one. - Posts 6,7,8, and factor against kubomans excellent brief description above.http://www.tractorbynet.com/forums/build-yourself/153093-h-f-quik-hitch-question.html
The center hook height is adjustable on most ... but some implements will not have room to engage that hook and you will need that alternate linkage accessory shown in some of the posts. Also there are implements that these hitches cannot be made to work on because there is not enuf clearance around 1 or all of its pins to maneuver the hooks into place.
larry
/ Pat's Quick Change question #54
larry
Thanks for the response. Straight answer, won't work on all implements. This I understand. I think this got started back in the thread when someone asked if we were against the fixed QH's. I was wanting to make certain that the reason I hadn't purchased one before was because they will not fit every implement like the arm extension QH's. As some times happens I seemed to not be getting a definite answer from owners of the fixed QH's as to cost and do they fit all implements. Apparently, now from owners of fixed QH's, they still do not fit all implements as I had come to the understanding before when I decided to buy Pat's instead of a fixed one. I believe I might would buy a $70 fixed QH if I knew it would fit all of my implements for certain just to try it but I'm not certain it will and I already have 2 different arm extension QH's so I'm saving my money and sticking to what I have. Maybe a company will send me one to try and if it works on all of my implements I can send the money.:)
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2019 KENWORTH T880 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T880...
2014 Takeuchi TS50R Compact Wheel Loader Skid Steer (A61572)
2014 Takeuchi...
