Front-End Loader How can you tell that your toothbar is from KY?
   / How can you tell that your toothbar is from KY? #1
Spiveyman
Central KY
Ford 6610 II
First of all Sandman, if you are out there, I'm sorry, really really sorry, but don't worry. I will get this fixed! ;)
Second, yes, that is right, it is when your toothbar only has TWO teeth. :D
Now don't get upset with me, I'm KY born/bred, so I can say stuff like that. It's not like I'm picking on WV or something. :laughing:
I have made comments in several threads out there about toothbars. This thread pretty much negates everything I have ever said about MY toothbar. Pretty soon it will actually be a toothbar, rather than a TEETHbar. :eek:
To recap, I have a Bush Hog FEL and following the advice of several TBN veterans out there decided to get teeth for my bucket to help me out because I tend to use it as a FED (Front End Digger) rather than a FEL.
I hope this will work, but here's my post about my teeth.
Spiveyman's Factory Teeth
I was very excited. You can go back a few posts to read about the decisions I made to go with the individual bolt on teeth rather than something like the Markham toothbar.
Fast forward and you can see the condition of my toothbar now. Here's the commentary that got me here.
I broke the first tooth off testing out a theory that someone posted that sometimes you can drive up to a tree that you want removed and that there is this perfect spot where you can just push on it and the tree will just fall over pulling the rootball up with it. (Smaller trees of course) So I did that. The first tree, probably only 14 or 15 feet tall, did just that. It plopped over and the rootball came right up out of the ground. I tried it on a few others with varying results, until I tried a maple tree with (I would find out later) a bionic root system. I pushed and [BANG] very loud noise as one of the teeth broke off. They break off at the weld point. There is a bracket that fits over the edge of the bucket with the tooth welded to that. The welds just gave up.
After that I decided to cut and dig. I don't have a back hoe yet, so this was my best option. I cut down several trees and began digging up the root balls. Now granted I'm a little outside of the recommended operating window for this bucket/teeth combo, but I read about people with Markham toothbars tearing up blacktop and stuff. I broke off the rest of the missing teeth trying to dig under a rootball. I'll tell that story in my other thread, because this one is more about the toothbar itself.
I went to replace the teeth and they want $73 EACH to replace. That is 7 missing teeth and one badly bent or $584 for those keeping track. Yikes! :( And they would be no better quality than the ones I started with. I can tell you that's not going to happen. So I finally yielded to the wisdom from the TBN vets and looked up Markham Welding. They have changed their name and are now "Gator Attachments at Markham Welding." Here's their website:
Markham Welding
I sent them an email and Melissa Markham responded immediately with a very reasonable quote and very reasonable shipping as well. So right away, customer service!! You don't find that very much these days. There are countless testimonials about the quality of these things. It will be a little while before I can order mine, but as soon as I am able I'll post a glowing review I'm quite certain.
Happy digging!
   / How can you tell that your toothbar is from KY? #2
LOL :laughing:
   / How can you tell that your toothbar is from KY? #3
We have a town around here that to live there you need to be missing one tooth. Kind of a standing joke in the area. Were you trying to do something like what is in these photos?
   / How can you tell that your toothbar is from KY? #4
Great story, and good thread about all your projects, yardwork, etc. I did purchase the Markham tooth bar and got the excellent service that you spoke of. Also, I have gotten good use out of the tool bar. I am still learning how to use mine, and so far nothing has broken off. I do think that is possible, however.
Tree removal with a FEL (even an FED) and no backhoe is not an easy chore. I have removed a few, but really feel like that puts pressure on the tractor and FEL that is just not good for it. Someone please correct me if I am wrong because I have several trees and roots that I would like to remove. It seems to me that the process calls for using one side or the other of the bucket, and that puts a torque strain on one side. Also, if I try to lift or curl with just one side under a root, my little CK30 kioti will come right up off the ground, and that can be butt curling.
I read with interest the thread about getting the tree stumps and roots out with an old tire rim, or device created to use some laws of physics to increase the strenght of the tractor pull. I have not come up with a device yet but plan to build something.
Keep up the good work.
Let me say, Yes, Yes and Yes. You are absolutely correct. This is not the best use of an FEL. I pretty much feel like I am right on the edge of breaking my FEL at any moment. Yes there was one point I was lifting with the left side of the bucket and throttling my tractor as well to try to push the root ball out and I noticed that the bucket was crooked. Being me, I simply turned the tractor around, did the same thing with the other side of the bucket, and now she's level again, more or less. :eek: There's also this funny sound now when I life the bucket, kind of a ticking sound. Hmmmm... well, I'm being more careful as I proceed. I have a relatively powerful tractor. My FEL isn't strong enough to lift the back tires with the bucket curl pressure, but it does get a bit light in the rear, especially when I'm on a hill facing down. There was a few times I had to drop the load and even use the bucket to "lobster" my way back up the hill. I think that's the term. I saw that in a thread one time where a guy got stuck and he used the bucket to get out. Anyway, I'm sure that there is a breaking point for the Markham stuff as well, and with my track record I'll probably find it, but overall it seems more stout. I'll also be smarter in how I use it. We'll see.
   / How can you tell that your toothbar is from KY? #6
Since we're making tooth jokes....
Do you know what makes the Nashville Predators unique among all National Hockey League teams?
They're the only team that collectively has more teeth than their fans.....
Thank you very much. I'll be here all night. Please remember to tip your waitress.....
   / How can you tell that your toothbar is from KY? #7
This is why the tines on Loader Buddy are placed inside the plane of the loader arms. Loads are shared by both arms virtually eliminating the probability of tweaking your loader, while still offering the possibility of snagging a root one at a time while working your way around a stump. The visibility when working this way is good too. I have grubbed many stumps and trees in ten years and still have an "untweaked" loader. The biggest being a 2' cottonwood stump, took more than an hour but it went to the burn pile in the end.
   / How can you tell that your toothbar is from KY? #8
What do you say to complement a woman from KY?
"Nice tooth"
Alright, that's actually a Maine joke...
JayC
   / How can you tell that your toothbar is from KY? #9
This is not the best use of an FEL. I pretty much feel like I am right on the edge of breaking my FEL at any moment. Yes there was one point I was lifting with the left side of the bucket and throttling my tractor as well to try to push the root ball out and I noticed that the bucket was crooked. Being me, I simply turned the tractor around, did the same thing with the other side of the bucket, and now she's level again, more or less. :eek: There's also this funny sound now when I life the bucket, kind of a ticking sound. Hmmmm... well, I'm being more careful as I proceed. I have a relatively powerful tractor. My FEL isn't strong enough to lift the back tires with the bucket curl pressure, but it does get a bit light in the rear, especially when I'm on a hill facing down. . I'll also be smarter in how I use it. We'll see.
This is exactly what I was doing when I broke the ring and pinion in the front of my tractor. When you are curling the bucket and going forward trying to pop out the root ball you are putting all the stress on the front axle. Let me tell you it gets expensive in a hurry.
Bill
   / How can you tell that your toothbar is from KY? #10
Must have invented the tooth brush down there other wise it would have been called a teeth brush. Sorry, I couldnt help my self.:laughing:
2014 Ford F-550 (A55973)
2014 Ford F-550...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2001 John Deere 6210 (A60462)
2001 John Deere...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
