Confused About SEC Cable Size
/ Confused About SEC Cable Size #1
paccorti
Gold Member
Hillsboro Virginia (near Purcellville)
TC35D with 16LA Loader
I'm wiring my barn for 100amp service. The main service panel that I installed (GE 100 amp) says that the input wire (from the meter) should be 4/0. Before I noticed that (on the panel) I bought 2/0 SEC wire. This wire seems huge. I've twisted the neutral wires together tightly but I can't come close to getting the twisted neutral wires into the lug on the neutral bus of the main panel. Normally I think of a large number (#4) wire being smaller than a #2 wire. Is that true for SEC wire and does that explain why I can't get the neutral wires to fit?
Note there is not electricity to the barn right now (meter is not hooked up).
Thanks,
Peter
Let me be more specific. On the panel it says the "Line 4-1/0 Cu-Al". Cu-Al is copper or aluminium obviously. I think this is saying that I can use a 1/0 wire (anything from a 4 to a 1). My 2 does not fit obviously (too big). My research leads me to believe that 1/0 wire is rated at 175 amps for service entrance.
Thoughts,
Peter
/ Confused About SEC Cable Size #3
i'm not by any means qualified, but i did a similar thing last year - i ran a 100a service form my house to my garage. i don't remember the specifics completely anymore, but i know that i ran 1/0-1/0-1/0-2 aluminum (4 wires due to carrying separate ground and neutral to a sub panel), and if i remember correctly, that was bumping up one size due to the length of the run (~200ft). i believe that 2-2-2-4 would have worked fine if i was closer.
as far as what your box says, i have a feeling that that may be the maximum wire size that the terminals will accept. also, when you see 4/0 think of it as if you were buying shotgun shells. that's really 0000, whereas 2/0 is 00. that should help explain the size difference.
edit: now that i think about it, i believe that the wire i used was suitable to carry 100a up to a distance of 190ft, and i ended up a little short of that. mine was a sub panel installation, and not a direct run from the meter.
/ Confused About SEC Cable Size #4
Why do you have 2 neutrals? I wired a 100Amp GE branch panel for my hot tub building a few years ago and used direct burial #2 -3 (three #2 conductors) with a braided ground shield. This was 2 hots and one neutral, like every other breaker panel I've ever seen. Neutral wire is always the same gauge as the hots. The #2 neutral wire fit the lug at the top of the neutral bar just fine, and I twisted the ground/shield braid and connected it to one f the larger points on the neutral bar.
/ Confused About SEC Cable Size #5
For short runs, 100'max, #2AWG copper meets NEC code requirements.
Where local codes allow, the neutral maybe reduced to #4AWG Copper.
#1 AWG is larger than #2. larger than #1 is 1/0 and the 2/0 and then 3/0 and lastly 4/0. The dividing line between #1 and 1/0 is sort of like the 50 yard line in football - cross it & the numbers go the other direction. Sizes larger than 4/0 use another vocabulary, so let's not get into that here. Larger wire than the NEC code spec may be called for because of the voltage drop over a long distance. I hope this helps.
SEC means SERVICE ENTRANCE CABLE
A[/SIZE][/SIZE]merican Wire Guage
Thanks,
Peter
/ Confused About SEC Cable Size #6
Sounds like you tied the neutral and the ground conductors together in your sub panel. That is a NEC no-no.
Lostcause doesn't have two neutrals. He stated quite clearly 1/0-1/0-1/0-2 aluminum, meaning two 1/0 hotlegs, a 1/0 neutral and a #2 ground conductor...4 wires due to carrying separate ground and neutral to a sub panel...as required by NEC.
/ Confused About SEC Cable Size #7
I was referring to paccorti's post. He said that he had 2 neutrals that he twisted together.
I have not run a separate ground for the sub panel, but I will eventually. The hot tub is currently out of commission anyway. Even my main breaker panel has the grounds and neutrals on the same bar though. Don't know if I've ever seen a panel that had a separate ground, other than when I specifically requested an isolated ground.
/ Confused About SEC Cable Size #8
The twisted ground braid should be connected to the ground buss strip, not the nuetral bar.
/ Confused About SEC Cable Size #9
Peter Go to Lowes and get a Sq. D # "1100 AN" neutral lug kit. Install it on your neutral bar and you should be all set. It comes with several size screws to adapt to your neutral bar,
Ok let me add a couple of things here. The meter and main panel are back to back (meter is outside). The SEC cable only needs to move the power from the meter to the panel (which is about 3 feet or less total distance lug to lug). The electric company will take care of transformer to meter.
The 2/0 wire also seems to big to fit into the main breakers (which power the panel) so I'm pretty sure that this wire is too big for the panel.
In my panel I have:
1. Main breakers (2 x 50amps came with panel these are fixed)
2. Neutral bus with 1 large lug
3. Ground bar
I don't have two neutrals, but the SEC wire has:
1 insulated black hot wire
1 insulated red hot wire
a bunch of uninsulated copper wires (braid?) surrounding the two hot wires
insulation around the whole thing (including braid)
So when I say I'm wrapping the neutrals together I'm referring to the collection of copper wires surrounding the two hots: those need to connect to the neutral lug (but twisted together they are simply too big). Note the hots are too big for the main breakers too.
For clarity the the ground bar in the panel will be grounded to a grounding rod using a separate copper cable (not using anything in the SEC cable for the grounding bar).
Also note: I'm not trying to cut any corners or do anything unusual, I want this to be a plain jane vanilla setup.
hilltopper34w
I guess ultimately I'm confused about the SEC cable size designation. If a 2/0 is too big then what wire size do I want for 100 amp service (remember I'm only going 3 feet lug to lug from the meter). I need two hots with the braid.
Peter
/ Confused About SEC Cable Size #11
as i posted earlier, i used 1/0 aluminum for a 100a panel, and that was increased a size due to the length of the run. i know that in my panel, i could not have fit anything larger into the lugs, as it appears you can't. wherever you purchased the wire may be able to tell you what size is required (most electrical supply houses tend to have charts to cover that).
if you do a simple internet search, the results seem to show that #4 copper is an acceptable size for a 100a service entrance. i believe that #2 would be the correct size for aluminum wire. you're several sizes larger than that. if you have 2/0 copper, i believe that can actually carry a 200a service. again, mine are fairly educated guesses, as i am not an electrician, and i didn't even stay at a holiday inn express.
wire sizes from smaller capacity to larger as follows:
14
12
10
8
6
4
2
1
1/0 (0)
2/0 (00)
3/0 (000)
4/0 (0000)
I think this explains what some of you were trying to tell me about SEC size.
According to this I could do a 4, 2, 1 or 1/0. Instead of a 1/0 maybe I'll do a 1 (THWN). It looks like the cable I have is rated for 200amps which way bigger than my panel.
Maybe that's what the panel really means a #4 cable to a 1/0 (on the panel it says 4 - 1/0)
Thanks for the help!
Peter
/ Confused About SEC Cable Size #14
14
12
10
8
6
4
2
1
1/0 (0)
2/0 (00)
3/0 (000)
4/0 (0000)
and then it goes to MCM. I have a chunk of 1000 MCM at home that I pulled out of a job. I think 2000 MCM is the largerst but have never seen any.
/ Confused About SEC Cable Size #15
Peter
You can use #4 for a short run as you describe, and yes that is what the panel means, #4 thru 1/0 will fit the lugs.
/ Confused About SEC Cable Size #16
RaT,
I have often used 500 and 750 mcm wire on some Govt projects and prefer to paralell the wires rather than going larger than that. I would think 1000 or 2000mcm would be tough to work with. What are you going to use the 1000mcm for? :confused:
/ Confused About SEC Cable Size #17
You should use a #2 for a 100 amp panel. But there is an exception in the NEC for residential use that lets you use a #4. These are copper conductors, I don't know what they bump up to for Al. So this is the smallest you can use.
You then need to figure out the resistance of the wire for the entire circuit with the conductor you're using and the length of the run. Then you use knowledge of your load to make sure there isn't too much voltage drop for your particular application. Remember that you have drop both to and from the panel. As already stated you need 4 wires which is what you said you had. The code also allows for a smaller ground, you'd have to look that up, ask here for an electrician, or consult an electrician.
I just put in a 100 amp sub panel, the run was 165' long, used #2 copper, and the drop at 100 amps is around 5 volts (if I remember correctly). The wire size was also influenced by bizarre pricing at a box store where #2 was cheaper than #4. This is also why I made the ground a #2 also.
So code dictates minium size, and the voltage drop might bump that up a size or two.
Pete
/ Confused About SEC Cable Size #18
RaT,
We pulled the 1000 MCM Cu out of a job and ran triple parallel runs of 750 MCM Al. The conduits were there and it made getting to the required current capacity simple.
Thanks everyone. I think I'll get either the 1/0 or the #1 SEC in copper. That seems well above code (and is the max or close to the max this panel can take anyway). The #2/0 was $8/foot so at least it will be cheaper!
BTW is there any convention for putting the red hot and black hot into the main breakers (for example put the red left and black right or something like that)? Given the interleaved arrangement of the hot buses to breakers I wouldn't think it would matter.
Peter
/ Confused About SEC Cable Size #20
Peter
It does not matter. Often times you just have two blacks so there really is no polarity issue. When using aluminum, be sure to come back the next day and re-torque the lugs.
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
SKYJACK SJ63AJ TELESCOPIC BOOM LIFT (A65053)
SKYJACK SJ63AJ...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2006 Freightliner Tuscany 4077 40ft Class A Motorhome (A64557)
2006 Freightliner...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2019 ASV RT-25...
