I filp flopped on a generator.
/ I filp flopped on a generator. #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
After much research I was **** bent on buying a generac 8kw or 17kw propane unit because of cost I was leaning towards the 8kw.I ended up buying the 17KW unit for about $1500 bucks extra.I had it installed today and needless to say I am impressed with this generator.Thanks to all for your input.coobie
/ I filp flopped on a generator. #2
I have been enjoying mine for 4 years and 95+ hours so far (I added a hour meter to mine). You will never regret buying the bigger unit!:thumbsup:
/ I filp flopped on a generator. #3
Generators, tractors, there's nothing like getting a few more KW/HP.
Now if you have the same experience I did, you'll not loose power for 2 years. Got mine in '97, it has about 250 hours on it. About 180 of those are "real".
Pete
/ I filp flopped on a generator. #4
I have had mine (15kw), for about 7 years now and it has yet to fail me when it was needed. Had it running for a week or so a couple of winters ago. We went on living while everyone down the road was calling to see if we got our power back. Then of course I said, I didn't know it was gone.....lol.
I have a company come out twice a year for service and never worry about it.
/ I filp flopped on a generator. #5
As a new comer I miss the background on this, but I do wonder what you paid in total for the setup.??
/ I filp flopped on a generator. #6
make shure to include any options included, like automatic start, transfer pannel, wireing hookup etc.
/ I filp flopped on a generator. #7
I've been itching to get a true "backup generator" for my home for years. I have a few of the little wheeled generators you can buy from Lowes..etc. They're great for keeping fridge cold and one room with ac during an extended power outage...which happens a lot with our rural power.
I'm wondering how much propane they use. If we have another hurricane like Rita, I'll be out for over a month. My entire home is electric so propane would be only for the generator. That being said; what kind of tank do you guys use? How often does it need to be filled and is it above ground or what? I understand the calculations for usage, but just don't know how long a 17KW generator could run at full usage on x amount of fuel.
According to my 17kw owners manual under FULL LOAD 2.51 gals per hour.I have a 500 gal. propane tank that will run my mine.coobie
/ I filp flopped on a generator. #10
I had an 8kw at my former home that was connected to our 500 gal propane tank which also served the house. It was listed at 2gal hr? under full load or something like that ....can't remember:confused: Anyway, that was never an issue. Whenever we'd go off the grid and onto standby we just paid more attention to what we were using. Your biggest draw will come from electric motors...fridge, freezer, sump/septic pump, well, heat/AC... you get the pix. But thats just when they start...something like 3 times the draw to start them, then to keep 'em running. The odds of all of them being called for at the same time is about a zillion to one. Now I'm talking about a conventional home with a combination of gas/electric. If your home is all electric, thats a different story.
I would say in your case a 250gal propane tank would be fine. 500 would be better. You can always call for refill if needed. The tanks do sit above ground but can be located quite a distance from home to not screw up your view.
/ I filp flopped on a generator. #11
Just remember if in a potential flood zone that propane tanks will float. A floating propane tank can cause quite a stir when it starts bumping into bridges, docks, etc...
Roy
/ I filp flopped on a generator. #12
i have a 17 kw propane generac it uses 1.5 gallons an hr, hand calculated, Runs great, powers whole house...
/ I filp flopped on a generator. #13
I have a 16kW Generac, and last winter we had a power outage that lasted 4 days. During the 4 days I ran it about 75 hours and used about 75 gallons of propane so my average consumption rate was just 1gal/hr. I was really glad to have it.
Low and behold we lost power today for about 3 hours(very windy here in michigan today)This auto generator is the cats behind.LOL.The wife said no buyers remorse on this purchase.coobie
