RTV1100 Delivered Yesterday
/ RTV1100 Delivered Yesterday
The joy stick setup I have now put the orginal curtis one to shame.coobie
I''ll bet..Use one hand to do everything instead of hitting a rocker switch and the hydro controller.
How does the power angle work in deep snow?..Do you have to lift it or will it angle while plowing? Haven't had an opportunity to try it yet.
/ RTV1100 Delivered Yesterday #22
You eventually get use to using electric lift and hydraulic angle but it is a pain. At least on the 1100 they put them both on the left side on the 900's the electric lift was on the right. We have curtis fast cast 550 spreaders on our rtv's. The controls on the 900's are on the rollbar in front of the passenger. When plowing you are dancing all over the cab trying to keep up with the levers and switches. On the 1100 they mounted the spreader controls on the left under the dash. A hydraulic joystick with two toggles for the spreader would be great but the university is to cheap. The power angle works great it is more powerful than the lift. We will be plowing and angle the blade to prevent plowing in other sidewalks as we are moving. If you get stuck you can sometimes use the angle to work yourself free. The hydraulic angle works great the electric lift works good but wish it was hydraulic. The lift and angle work great in deep snow I have pushed back piles that were above the hood and adjusted the angle no problem.
Thanks Sportsman,
I'm assuming that you have the standard Curtis plow, not the commercial version.
If that's the case, I feel pretty good about this..
/ RTV1100 Delivered Yesterday #24
/ RTV1100 Delivered Yesterday #26
Not to sound stupid but what is the difference between the commercial plow and the standard one?
/ RTV1100 Delivered Yesterday #27
TIMSWI how does the suspension compare to the 500. Is it a little stiffer, softer or about the same. I have always thought the 500 rode a little rough. I was in a bobcat utv that almost beat me to death. Seems like your enjoying the new ride so far since I haven't seen any complaints.
It does ride much nicer than the 500..Although the snow plow is on it. Once that weight is off, I'll know better.
I do like it so far. It feels and looks alot bigger than the 500 even though it isn't THAT much bigger.
The hydolics are going to take some getting used to..They are really fast, actually way too fast. Have to really watch what you're doing with the power angle and the bed. Practice on that one I guess.
The cab is really nice. Just wish that the cloth seat was a blackish grey instead of silver...That's going to get messy looking pretty quick. Seems kinda silly to buy seat covers for $90 to prevent that.
So far so good though.
The diesel is a serious improvement over the 500 gasser.
From what I can see, the commercial is bigger and orange. The Curtis is black and a little smaller. The dealer said that the commercial one is really expensive and they've never sold one.
They also have V angle plow. Actually if you're doing sidewalks, that one would be ideal. I'd hate to see what it costs.
/ RTV1100 Delivered Yesterday #30
Looks pretty nice. How's the shifting? Do you really have to yank it out or does it just kinds slide nice and easy? That's my biggest complaint. Mine has to be jammed in or yanked out.
The main tranny shifting is fine..Had a few issues getting it out of 4wd..
I just gas it a little, and let off if the range lever if it get's stubborn..No different than the 500 acted.
/ RTV1100 Delivered Yesterday #32
I don't know how his has been, but that was a problem I had with the RTV900 but not the RTV1100. Here's where I posted about the RTV having problems getting stuck in gear almost 6 years ago. http://www.tractorbynet.com/forums/atvs-utility-vehicles/38365-rtv-hill.html If they haven't fixed the problem by now, it isn't going to get fixed IMHO.
/ RTV1100 Delivered Yesterday #33
On our 900's the tranny will bind up on really bad. If you keep giving it gas as you apply massive pressure on the shifter they normally will then shift. The 1100's have a knob you can pull to release pressure in the transmission this is great because when plowing you bind up the tranny a lot. When we are plowing if you have a rider the rider pulls the knob so the driver can shift and raise the plow / turn off the spreader at the same time. Shifting out of 4wd well it is just like the 900 sometimes easy and sometimes you have to accelerate. I have not had any troubles shifting into 4wd. On a side note, the bump on the shifting gate to make it more difficult to shift into reverse has worn out on our 900's because of snowplowing. Our plows are all standard plows no commercial plows. They are built strong enough no need for a commercial plow.
Well... I was able to take my daughter out for some rides tonight and last night in downpours. Could never do that before.
Right now she has casts up to both knees and can barely get around, but when I asked her if she wanted to go for a ride...I got the biggest smile you can imagine, and she motored herself to the back door.
Sometimes the cost of stuff just doesn't matter...This is one of them.
/ RTV1100 Delivered Yesterday #35
TIMSWI your one heck of a great Father. Made me feel very happy for your Daughter that she enjoys that 1100. You are so right about the cost of the RTV $20,000.......smile on your Daughters face after surgery with cast on both legs.......PRICELESS.......Know we are all pulling for her and wish her a speedy recovery...God Bless my friend.
P.S. I beleive you just might have sold me on the 1100 with the rain story!
Thanks for the wishes 737..I'm not a great father, but I try. She's slowly getting more mobile which is nice to see. First day back at school today, and going to some of the different rooms completely wore her out. So, they're going to move her around in a wheelchair while at school to make life a little easier for the next month.
If you look around, there may be some 09 leftovers. That's what mine is. I paid a little over 19K with the snow plow, bed liner and front/ rear work lights. I think the base machine was in the 16's. 0% financing really makes it tempting.
Take one for a ride, I think you'll like it...This thing is a TANK.
Mine doesn't have the release knob, at least one that I can see. Is that an option?
/ RTV1100 Delivered Yesterday #38
No, the newer ones have the release integrated into the brake pedal now, would like to get the cable and bracket to upgrade mine as if it binds you have to hit brake, pull release and shift at same time.
David Kb7uns
David Kb7uns
Thanks for that info..Was wondering.
Took the plow off today...Not as easy as the 500 was, but not too bad. The 2 rear subframe bolts are kind fun to remove. 1ft extension and a universal joiunt on an air rachet...Couldn't a straight shot be built in?...
/ RTV1100 Delivered Yesterday #40
David Kb7uns
That would be nice to have. If someone is riding shotgun then they pull the knob to release the tranny so that the driver can shift and lift the blade at the same time. When you are driving it on own than you wish for a third hand.
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2020 Chevrolet Silverado 5500HD Dump Truck, VIN # 1HTKHPVK0LH288017 (A61165)
2020 Chevrolet...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
