RTV1100 Delivered Yesterday
   / RTV1100 Delivered Yesterday
Thanks Randy,
That's what I did..Tthe rear of the plate just sits on the ductwork. No attachment points anywhere( for the plate that is). Guess that's the way it is.
Need to pull it back out and put more bushings on it. The radio isn't level in the dash, once the foam on the ductwork matted down. Kind of a cheezy design. They could have done a little better on that one.
   / RTV1100 Delivered Yesterday #12
We did not put a radio in ours the university would frown on that, they only buy the 1100 because it is cheaper to buy than putting a cab on the 900's. Our cord is actually bunched up and hangs below the dash. The face plate covering the radio hole was rattling so I made some masking tape spacers to stop that.
   / RTV1100 Delivered Yesterday #13
I sure hope it works out for you,good luck.coobie
   / RTV1100 Delivered Yesterday #14
One more thought,replace those cotter pins in that curtis plow snow/skid shoes ASAP.Trust me on this one,mine came off after the first couple of uses.If I am correct the snow/skid shoes are $80.00 bucks(pair) and you cannot buy one you have to buy two.I am speaking from experience,LOL.coobie
The ones on this look similar to the cotter pins on the RTV500, never had a problem with them..What happened to yours? I don't want to buy new ones, that's for sure.
   / RTV1100 Delivered Yesterday #16
Mine would spin while plowing and get bent and work there way out of the hole.I ended up changing my whole curtis plow setup to a heavier skid shoe,and 1/2 cutting edge and got rid the electric lift, and went full hyro lift&angle changed front set up to more heavy duty and angle without loosing my dump bed lift.My kubota dealer said it could not be done but the good folks at michigan iron and equipment proved that different.coobie
Mine would spin while plowing and get bent and work there way out of the hole.I ended up changing my whole curtis plow setup to a heavier skid shoe,and 1/2 cutting edge and got rid the electric lift,angle and went full hyro lift,changed front set up to more heavy duty and angle without loosing my dump bed lift.My kubota dealer said it could not be done but the good folks at michigan iron and equipment proved that different.coobie
I actually don't use the skid shoes. I am going to attach a machine belt to the bottom of the plow as I did on the 500. This plow is a little lighter, so that should work even better.
Got any pics of the new setup? That sounds nice.
Did they add a separate hydro controller to run different stuff. Mine only has one controller, ergo the dump bed is disconnected at the quick connects in the rear.
   / RTV1100 Delivered Yesterday #18
I used to have pics but not anymore.The folks who did the change are site sponsers at the Kioti website,the name is michigan iron and equipment,the owners name is Bob piro(517-625-4590.I have a in cab joy stick for lift and angle,dang nice to boot.coobie
The joystick should be standard equipment.
   / RTV1100 Delivered Yesterday #20
The joy stick setup I have now put the orginal curtis one to shame.coobie
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58216)
WHISPEREATT 25...
10' Fork Extensions (A57149)
10' Fork...
