Yanmar B7 Excavator
/ Yanmar B7 Excavator #1
sos1
My son bought a B7 and found the hydraulic motor for the cooling blower doesn't work. It appears to be connected to a hydraulic control valve with what appears to be an electric solenoid attached to the control valve. Does anyone have any info that might help in diagnosing the problem and fixing it?
Thanks!
/ Yanmar B7 Excavator #2
I don't own a B7 but do you think that the fan might be thermostatically controlled? Maybe that "solenoid" is a temp sensor. Try jumping it an see if the fan comes on. Just a thought from me. Good Luck
SimS
We had that thought and did just as you suggested. The solenoid does activate, but the motor doesn't run. I thought the valve might be stuck
and not opening. We're trying to find a service manual.
Dominion Equipment deals in gray market machines. I'm going to
contact them.
Yes, Serial # 00501B
2025 SZYMJ Hydraulic Stump Grinder Skid Steer Attachment (A64553)
2025 SZYMJ...
2012 Freightliner M2 106 S/A 14ft. Cab and Chassis Truck (A64194)
2012 Freightliner...
12in. Bucket w/ Teeth Excavator Attachment (A64194)
12in. Bucket w/...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
2018 CATERPILLAR CB13 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
