Yanmar B7 Excavator
   / Yanmar B7 Excavator #1
sos1
My son bought a B7 and found the hydraulic motor for the cooling blower doesn't work. It appears to be connected to a hydraulic control valve with what appears to be an electric solenoid attached to the control valve. Does anyone have any info that might help in diagnosing the problem and fixing it?
Thanks!
   / Yanmar B7 Excavator #2
I don't own a B7 but do you think that the fan might be thermostatically controlled? Maybe that "solenoid" is a temp sensor. Try jumping it an see if the fan comes on. Just a thought from me. Good Luck
SimS
We had that thought and did just as you suggested. The solenoid does activate, but the motor doesn't run. I thought the valve might be stuck
and not opening. We're trying to find a service manual.
   / Yanmar B7 Excavator #4
Have you tried a Yanmar dealer?
Dominion Equipment deals in gray market machines. I'm going to
contact them.
Yes, Serial # 00501B
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
