yanmar 1602
/ yanmar 1602 #1
carpeux
Hello,
French and I am sorry if the translation is not great, as done by Google.
I have a yanmar 1602 and I want to change the filter for the hydraulics, but can not find an equivalent in France.
Have you the original reference, or tell me what model you put in place.
Thanking you
/ yanmar 1602
I managed to find a filter to replace the original one.
hifi SH66218
Thank you to you
/ yanmar 1602
Before I change the filter, is there a strainer to clean somewhere?
Thank you has you
/ yanmar 1602 #4
I'm not sure of your model. Most models have a 3 bolt flange toward the front of the transmission. Screen would be behind flange.
/ yanmar 1602
I have 1 plate with 3 bolts on the tube just before the filter, another on the housing just after the filter and 1 on the left crankcase.
This is where I must dismantle?
Thank you very much
/ yanmar 1602 #6
Thank you very much
The cover for the hydraulic screen is on the left side, just below and to the front of the left brake drum cover, there are 3 6m x 20m screws that hold it on. I would replace the hydraulic filter with the OEM filter, the hydraulic filter for the YM1602 is the most inexpensive of all the Yanmar hydraulic filters, just because a filter fits does not mean that it is the correct one.
Danny
/ yanmar 1602
Thank you very much everybody, I dismantle the plate to clean the strainer, and filter I finally took a leeftguard HF6281 because others do not have the same filtration as the origin.
Thank you again, because here in France nobody knows what model tractor.:thumbsup:
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A64279)
2013 CATERPILLAR...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
UNUSED WOLVERINE PT-16-01C 3 PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2004 Dodge Ram...
