Comparison 50 or 60 series kubota?
/ 50 or 60 series kubota? #1
dirkster
Are there any differences between the 50 series and the 60 series BX tractors? If so what are they and how important are they? Thanks
/ 50 or 60 series kubota? #2
Moved to Kubota Buying/Pricing forum.
/ 50 or 60 series kubota? #3
After buying several Kubotas I bought a BX2350. Plastic hoods and stuff didn't bother me but plastic hood didn't close correct. The safety switch in the seat was bad because I had to lean back all the time to keep the engine from dying but I think someone has came up with a simple fix for that with shims, I believe. The abrupt stop in reverse was so bad that I traded the tractor in less than a year to a BX2660 which has none of the aforementioned problems. So, for me the abrupt stop in reverse was the only real issue now that I know about the easy safety switch fix.
/ 50 or 60 series kubota? #4
Hood and fenders were changed from plastic to metal. Some prefer each.
Hard reverse stop was corrected. Very Big deal to some, annoyance to others.
The higher Hp 2660 was added to the line. Has 2 more Hp and nice reclining seat. Particularly good if you need a nap I guess.
/ 50 or 60 series kubota? #5
I own a 50 series and driven a 60 series, I am gonna sit back and watch this thread for awhile. ;)
I'm looking at buying a new or slightly use BX just wanted some input. I think the 2350 or 2360 will suit my needs
/ 50 or 60 series kubota? #7
Dirkster- go with the 60 series. the reverse issue is enough to convince you the extra few bucks is worth it. no question asked. Lets not get into the plastic or metal, reverse,3 pt option, etc issues. I have the 50 series and will not get rid of it. I like it except for one thing-the reverse issue. I am willing to working at ideas to modify something to make it more bearable though. Its really the same thing 50 vs 60, everything else is cosmetic.
/ 50 or 60 series kubota? #8
The 30 series don't have this flaw either.
2018 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A59906)
2018 FREIGHTLINER...
2014 FORD F-150 (A60736)
2014 FORD F-150...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
