need a new tractor
/ need a new tractor #1
francessca135
Western PA
Massey Ferguson 135
We are looking for an agricultural farm tractor that is at least 75 hp and is able to have a front-end loader and back-hoe attachment. We currently are using a Massey Ferguson 135 diesel with 45hp. Needless to say we hold our breath when we are cutting/baling hay and pulling wagons. We are trying to find an agricultural tractor that will have the power to handle our hay equipment and also support a back hoe and front-end loader. Do you have any suggestions? We plan on keeping the Massey Ferguson. We have visited Kubota and John Deere Dealers with not much enthusiasm from sales reps. in actually listening to us and what our needs are. Could you assist us in recommending an all in one tractor?
Thank you for your time,
francessca135
/ need a new tractor #2
Both John Deere and Kubota offer several tractors which will meet those requirements. I would be suprised if neither dealer was interested in a sale like this. Did you discuss a budget with the dealers?
Steve,
Bugdet discussed, cash and carry deal. It was Feb 2009 when we went shopping. We are planning to revisit the John Deere and kubota dealers in a few weeks, but I am set against dealing with the same reps. My husband is set on kubota and from what I have test driven they appear user friendly. Is there a specific model from each that you would recommend focusing on?
Thank you for your time.
francessca135
/ need a new tractor #4
francessca135
I do the same with my 1964 MF-135 diesel. It needs clutch and tranny servicing soon. Not looking forward to splitting that little beast.
My haying tractor is a 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, gear tranny, power steering) with the ML250 FEL (6-ft wide bucket, 2950 lb lift). I pull a MF124 baler (small squares) with no problem. (I plant oat hay on 6 of my 10 acres).
I have a skid steer quick attach system on the FEL (highly recommended) and triple hydraulic remotes (also highly recommended)
For your needs the Mahindra 8560 with the 511 backhoe and the ML282 FEL is a possibility
Farm tractors for Ag Farmers, Hobby Farmers - Sub Compact, Compact & Full Size 2WD & 4WD Utility Tractors
Good luck in your search.
/ need a new tractor #5
You or your husband should be visiting the JD and Kubota web sites, comparing models and specs and using the build-your-own feature to get a fix on prices. It helps to go into the buying situation armed with facts and something definite in mind. Maybe you could come here when you've narrowed the field a bit and ask for the pros and cons of your choices. Once you get some quotes from dealers, the folks here can help you determine whether you're getting a good deal. Though shopping isn't for everyone, most everyone here finds tractor shopping enjoyable.
That said, you might take a look at the Kubota M7040SU. It's a basic utility version of their M7040 without the bells & whistles, yet with a strong, proven engine and design. At 68HP it's a little below your target HP range, but I think you would see a substantial savings over the next step up in HP, which is the M8540. The 7040SU has the same hydraulics as the M7040 and takes the same strong and proven loader. It does lack the hydraulic shuttle-shift & clutch of the M7040 and has 4 reverse gears instead of 8.
Actually your little MF135 is adequate for a light haying operation and that fact that it's stood up for you indicates that the 68HP M7040 would probably do fine. When my Dad was still around, we hayed for years with a little Ford 2000 and thought the only thing it lacked was a good slow 1st gear. Other than that, it was fine with just 35HP.
My two larger Kubotas, the L4300 and MX5000 are both utility versions. They're simple, straight forward basic tractors that have been very reliable and have given very good value for the money. Unlike the Deere basic utility tractors, which are somewhat dated designs assigned to manufacturing plants in India, the Kubota utilities are simplified versions of current designs built in the same plant.
You're wise to get the Massey some help before it gives up. Two tractors will make the work go faster....especially if there are two operators.
Bob
/ need a new tractor #7
have you considered a New hOlland. Very good cash incentives right now. Most other brands can't come close to the cash incentives they have at the moment,
/ need a new tractor #8
I sugest getting a dedicated TLB for the loader and hoe needs ( plus the loader on a industrial based tlb will likely be better off than a farm tractor loader setup ).. that said, then get a hp tractor needed for your hay needs.
soundguy
We are looking for an agricultural farm tractor that isat least 75 hp and is able to have a front-end loader and back-hoe attachment. We currently are using a Massey Ferguson 135 diesel with 45hp. Needless to say we hold our breath when we are cutting/baling hay and pulling wagons. We are trying to find an agricultural tractor that will have the power to handle our hay equipment and also support a back hoe and front-end loader. Do you have any suggestions? We plan on keeping the Massey Ferguson. We have visited Kubota and John Deere Dealers with not much enthusiasm from sales reps. in actually listening to us and what our needs are. Could you assist us in recommending an all in one tractor?
francessca135
/ need a new tractor #9
We have a couple of tractors in this size, so I haven't kept up and can't help with that. We have found out however that our "need" of a backhoe is such that our backhoe isn't even running now and it has been easier and cheaper to rent this stuff when we need it.
My brother is going to work on our backhoe when he retires to maybe do some side jobs, but we just don't need one very often around our farms.
/ need a new tractor #10
No offense ment BUT...
I see a lot of people grumbling about the lack of intrest paid to them by one or more dealers when they go shopping. I am not a tractor sales man but I would bet that a good salesman/woman can see who is there to talk business and who is just looking.
In the case of the OP they went looking a year ago and are now thinking about getting a tractor. I bet if your serious about a purchase you will have more help than you want from either dealer.
I say this from experience. I looked for a LONG time before I was ready to buy. In the begining no one paid much attention to me. Some how when I got ready to talk serious EVERYONE was willing to spend what ever time it took.
Give em another try. If your ready I bet you will be supprised at how helpful they are.
/ need a new tractor #11
I would recommend that you look very closely at a Deutz Fahr Agroplus 87. Google the site for your local dealer, or email me and I'll help.
Thank you everyone for your time and suggestions. I will review the information with my husband and will post result. Again, Thank you for taking time to assist us.
francessca135
/ need a new tractor #13
Steve,
francessca135
I would think a John Deere 5085M with power reverser and 70 pto hp would be a good choice.
Hello everyone, I just wanted to update you all on our status with getting a new tractor. After WEEKS of visiting tractor sites and businesses, we decided on a used JD 2955 4wheel 97 hp, pto @86 hp. It will be coming this weekend. We needed a few things done on our punch list one of which was a roll-bar added. We went to numerous tractor businesses and still got the same response "if you have any questions just ask, I'll be in my office". when asked to take a test drive, "it's too much trouble to get out of the show room" I told my husband if I had enough time I would go back to each business and show off our purchase like Julia Roberts did in "pretty woman". The person that we got the JD from PUT DOWN his tools and stopped what he was doing and went through the tractors he had with us and let my husband test-drive them around. There is a NOTICABLE difference in the integrity of this man and that is why we dealt with him. Our "give a ****" is NOT busted any longer.:)
francessca135
/ need a new tractor #15
Congratulations on your new tractor. Dealerships in our area run about 50/50 on customer service.
/ need a new tractor #16
Francessca,
Hope this works out for you. Is this a mechanical front wheel drive or hydraulic operated front wheel drive tractor?
2022 MACK ANTHEM AN64T 6X4 T/A  SLEEPER TRUCK TRACTOR (A59910)
2022 MACK ANTHEM...
SET OF (20) ACE CATTLE PANELS W/CONNECTING JOINTS (A63569)
SET OF (20) ACE...
Bandit 250XP Wood Chipper (A63118)
Bandit 250XP Wood...
2025 Polaris Ranger 1000 Side by Side (A64047)
2025 Polaris...
2004 TMP 32' T/A PIPE TRAILER (A63569)
2004 TMP 32' T/A...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
