JD 2000 Series Specifics Needed
/ JD 2000 Series Specifics Needed #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
OK, the 2305, 2320, 2520.
Each "step" up seems to be longer wheel base, if I read the specs right.
If you know, which uses the HST fan, of fragile repute, and which do not?
Any other recommendations as to differences, bang for buck especially helpful.
/ JD 2000 Series Specifics Needed #2
The 2305 has the infamous HST fan which is prone to problems.. The 2320 and 2520 do NOT have the exposed fan (but im not sure how they cool the transmission though)..
I have a 2320 and it is a very nice size for my needs.. I wanted to little bit larger frame (over the 2305) due to the rough cutting i do..
I hope this helps
brian
I think that the 2520 have a problem with the lift arms hitting the rears tires..
/ JD 2000 Series Specifics Needed #3
I had a 2210 & traded it for a 2320. The 2210 is the older version of the 2305. I believe the 2320 is the best bang for the buck. I looked hard at the 2520. It has been awhile since I traded so I do not remember all of the details. As I remember, the 2520 was over $2,000 more than the 2320. The specs were not that much different. I have been very happy with the 2320. It is a great all around tractor.
/ JD 2000 Series Specifics Needed #4
I hope this helps
brian
Correct, the 2210/2305 is the only one with the fan. The others are cooled with a oil cooler that is just in front of the radiator.
Thanks guys. Scratching the 2305 from the list.:)
Can you help a guy out with real world comparisons between the 2320 and 2520. The 25 in direct injection while the 23 in indirect? Any big deal between that difference?
Ground Clearance?
Operators station?
3 pt control? Especially for middle buster plowing and single row cultivation.
Pretty much snow plowing and farmer questions, because that is pretty much what I do with a tractor.
/ JD 2000 Series Specifics Needed #6
Hello bp fick
Without getting too involved (long winded:)),indirect is a little quieter running than direct,but isn't as efficient because the fuel is ignited in a prechamber then pushed into the combustion chamber to finish the burn. Direct is just that,everything takes place in the combustion chamber. There are other pluses and minuses,but that is the biggest difference.
One of the other main differences between the two models is the speed of the hydraulics,to say the least,night and day. I've seen a 2305 (my neighbor) with a FEL moving last weeks snowstorm and my 2520,man what a huge difference in the speed.
Another thing too,is the 2520 has a 40 amp alternator,where the 2320 has the same 20 amp as the 2305:(
I'm sure others will chime in too.
IMHO,if you are contemplating between these two CUT's,if you could swing it,get the 2520,there are more reasons to,than not to:)
Greg
/ JD 2000 Series Specifics Needed #7
I have a 2320 that is about 1 1/2 years old now.
It's a great tractor and well worth the $$
I realize the 2520 has faster hydraulics but 1.5 seconds or what ever it is to lift the loader full height is not that important to me to spend extra $.
It mowes great with the 62D mower in low or high range, has ample power for ground engaging equipment and so far trouble free.
The 3PH doesn't hit the tires and I've had several different attachments on it.
I just wish it had a tool box.
/ JD 2000 Series Specifics Needed #8
X2, Except the mowing part, I don't mow with mine.
Anyone want to offer guidance on the ground clearance difference?
Operator's cockpit differences, if any? 3 pt hitch differences, if any?
2320 versus 2520
/ JD 2000 Series Specifics Needed #10
As I remember there was not a lot of difference in ground clearence.
The 2320 has a flat foot platform, the 2520 has a hump in the platform.
The 2320 has a mowing deck height adjustment knob in the platform.
I do not remember how the deck height was adjusted on the 2520. I do remember that was one of the features that moved me to the 2320.
I believe the 3pt hitch on the 2520 can lift about 100 lbs more than the 2320.
I believe the above information is correct, but it has been almost 3 years since I test drove the 2520.
/ JD 2000 Series Specifics Needed #11
2320 versus 2520
Both tractors have the same ground clearance - 12.5" - Which doesnt make sense because the 2520 bigger tires.. But that is what the deere website says..
Brian
/ JD 2000 Series Specifics Needed #12
The 2520 deck height is done with the rockshaft. It has the 3pt position control,which the 2320 does not,but as you stated the 2320 does have the deck control. I guess that is why alot of 2520 owners opt for the independent lift for their MMM deck.
All in all,they are both great machines for sure:)
Bp it might benefit you to do some searches for 2520/2320 comparisons. I know there are plenty of them out there:D
Greg
/ JD 2000 Series Specifics Needed #13
The frame on the 2320 is approximately 14 inches wide while the frame is only about 10.5 inches wide on the 2520. When I compaired the 2320 to the 2520 I thought the 2320 was made a bit better. I said to myself at the time, the 2520 was an after thought looking for a market niche.
/ JD 2000 Series Specifics Needed #14
Brian
Front Axles are the same with the same tires, Clearance is the same.
/ JD 2000 Series Specifics Needed #15
Greg
The 2320 has postilion control on the 3PH, only the 2305 does not. All the 2x20 series use the rockshaft/3PH arms for deck raising/lowering, with the independent lift optional.
Thank you guys, really. These are the kinds of real world insights for which I asked. Deeply appreciated. Glossy .pdf files only say so much.
Leaning toward the 2320. Just wanted to be sure I wouldn't give up a "killer" feature or two from the 2520.
I am getting confusing stats on the ground clearance. Some websites (Deere) seem to list the clearance as 244 mm which is approx 9.5" while others, listing it in inches as 12" plus. Well, it can't be both!!:D This is a drop, stop and roll issue for a vegetable farmer like me. Again, very grateful for the feedback.
Greg
Greg, thanks but no. I have read some of these other threads, but I have found it much better to ask specific questions and get specific answers to what I want to know. When I have to travel 60 miles to the Dealership, I want to be very well and very specifically informed. Thanks for your help.
I am going to need some explanation of the 3 pt system. I won't be mowing grass, so the deck lift is irrelevant. Interesting, but irrelevant.
/ JD 2000 Series Specifics Needed #18
What happened to your BX1860?
DYNAPAC CP-2700 PNEUMATIC ROLLER(INOPERABLE) (A67714)
DYNAPAC CP-2700...
2014 DIAMOND C 45HDT CAR HAULER (A67714)
2014 DIAMOND C...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
OK TRUCK & TRAILER SALES PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
OK TRUCK & TRAILER...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
2014 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2014 (INOPERABLE)...
