REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES
   / REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES
[quote=Happyman;1883399]How did this get from SUDT to tires?[/quote]
Now you can't start in the middle of a thread and know the progressive steps of moving from oil to tire to resolving world conflict to stopping hunger and unemployment.:) Same goes for you LBrown.:)
LBrown59Re: REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES
Quote:
That is a good question.
While getting ready for Church today, I pondered this situation a bit more thoroughly. I think I have it figured out!:) Those of us that have BX's or a bunch of us that have BX's know that one front tire/rim is bad. I figured out that Kubota had bought a bunch of bad rims or tires and for some reason they didn't get the supplier to replace them. Maybe the supplier went bankrupt. I believe they have 2 stacks of mounted tires for the front of BX's.The stack of good ones and the stack of bad ones. Now they only put one bad one on each machine because you rarely hear of anyone having two that go flat on the front, just one. I believe what they done on the change over was planned at the beginning of the run on the BX24 and BX2350 that they were going to supply the new manuals indicating no SUDT fluid change at the first 50 hour service. Now, don't quit on me yet, I'm getting there. When change over time came some idiot in publication ordering had ordered more of the old manuals or the publisher did not make the changes and it wasn't caught until mid run. So as with the run of bad BX front tires the company to save money continued sending out new machines with the old manual until all of the old manuals were depleted then started sending out the new manuals. Therefore we have BX24's and BX2350's with different manuals. Now they got rid of all them old manuals by the time the BX25 and BX2660 came out so all of them will have the new manual. Now this is how my mind works and this is what I think happened until someone comes up with a better theory or the Company Rep calls or writes me something different.:) Now I have started thinking again after having stopped for a few minutes and I now believe my theory will be quoted in future forums as "The Kubota representative said (my theory) I read it/heard it or saw it.:)
   / REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES #32
My BX24 purchased new 3/6/08 has had a left front tire problem since day one. When it went in for 50 hr service they replaced the valve stems, checked and said everything was ok. Wrong! Just sitting, somedays it doesn't lose anything and the next day it might be almost flat. Now they want me to buy an extended warranty - maybe they'll give me some free air for my tire.
   / REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES #33
I had one front tire leaking air also. Slimed both front tires and haven't had to add air in over a year.
   / REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES #34
Now with these leaky tires...would it be better to fill them with UDT or SUDT? Just askin'.
   / REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES #36
You are correct, of course. I've got turfs and they're filled already with something else so I guess I'll leave them as is.
As far as the hydraulic fluid, I'll stick with the UDT and change both it and the filters at the recommended intervals - maybe even a bit sooner.
   / REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES #37
Perhaps the bigger question might be whether one should just skip the money that Kubota charges and fill our tires with some $19 bucks a gallon, no brand from the local farm store? I'm thinking it will work just as good.:D
   / REPLY FROM KUBOTA CONCERNING 50 HOUR FLUID CHANGES #38
Use 50/50 udt and sudt then throw in a little windsheild washer fluid so it can be used in Turfs Ags and R4s.:D
You guys are getting confused. 1. Only one front tire leaks 2. Only turf tire leaks 3. Only one front turf tire on BX's leak. So, don't put the stuff in all the tires or on other than a BX and only in the one front one on the BX that leaks. Do I have to tell you guys everything. Don't waste your money on SUDT in this case since it is thinner and more likely to leak. In fact get the thickest gear oil you can get and mix some sawdust with it. You can wait till the totally flat interval is reached before adding or you can do it early. As soon as you see the tire is going down, fill. Factory warranty will apply in either case.
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
WEATHERGUARD TOOLBOX (A50854)
WEATHERGUARD...
Unused Delta Crash...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A49461)
2021 Fleco DX140...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
