Another CCM Hydraulic Top Link
/ Another CCM Hydraulic Top Link #1
Luremaker
Ontario
Kubota L3130HST & NH TC18
I received my hydraulic top link from CCM today. The hose ends and cylinder openings were not sealed when it arrived. Should I clean the hoses as I have read here in TBN before installing?
/ Another CCM Hydraulic Top Link #2
You could either blow them out with air, or pull a small lint free rag through the hose.
/ Another CCM Hydraulic Top Link #3
Good news- maybe mine are on the way- I placed an order- about a month ago- they were out of stock- then the weather slammed them - yikes!
/ Another CCM Hydraulic Top Link #4
If it doesn't look dirty, I'd put it together and not worry about it. You're gonna love that HTL.
/ Another CCM Hydraulic Top Link #5
My 'biggest' issue with my HTL is there's no place to 'hang it' since it's too big to fit in the one the manual top link does. Has anyone come up with a solution?
/ Another CCM Hydraulic Top Link #6
Since I use a iMatch QH, it's always connected-no floppy TL for me:D
I placed my order with Mark on the 18th of January and it shipped Monday the 8th of February. I know Mark said they were really busy getting ready for a farm show. I ordered the 21-32" along with the hoses.
I gave the hoses a blast of air right after I took them out the of the box. I was thinking about the post which mentioned using solvent to clean the hoses.
...You're gonna love that HTL.
I agree. I just had to have the HTL after watching Rob's (3RRL) video and reading how everyone love theirs. It's taken me over four years of getting off the tractor to adjust the TL to see the benefit of having the hydraulic one.
Mike why not go buy a length of 3/16" rod and bend a larger replacement TL hanger. I'll pick up some rod this week and see if how it works out.
/ Another CCM Hydraulic Top Link #11
Don't know if you can tell in the pic or not. I bent the stock top link holder 90 degrees and it know hooks onto the cylinder fluid outlet that is at the closed end. Works great. I had to do some major reworking of my stock top link holder on my 7520 so that it would hold the hydraulic top link on that tractor.
/ Another CCM Hydraulic Top Link #12
Looking forward to see if this works. :)
/ Another CCM Hydraulic Top Link #13
Mike, I don't know if your hanger is vertical like MtnViewRanch's or horizontal like mine. I found that since mine is horizontal, I can hook it under the rigid tubing between the DPOCV and the cylinder fitting. The rigid tubing is plenty strong to hold up the weight of the HTL.
If you can't get your holder around the tubing, you might put an S-hook on it and bend the hook shut on both ends so that it stays in place when disconnected.
/ Another CCM Hydraulic Top Link #14
I ordered mine yesterday. The lady that took my order told me that it would ship today. Maybe I'll get it tomorrow. I live in Alabama, so it's not that farm from CCM.
She told me that mark was sick and out for a couple days.
Chris
/ Another CCM Hydraulic Top Link #15
The hanger is horizontal like yours. I will try your suggestion. Thanks! :)
/ Another CCM Hydraulic Top Link #16
Hi Steve,
Hope by now you have that hydraulic top link installed and working?
We sure want to hear your feedback and photos of it. Like Jim said, you will certainly love it and wonder why you didn't get it 4 years ago ...lol. Even attaching your implements will be easier rather than cranking out the manual one to line up the pin hole. Let alone the benefit form adjusting it on the fly.
As for the hook to hold the cylinder, like you were saying, I just formed a new shape so it would fit the cylinder. After all, I'll never have the manual one on again. right? I also have a really big tool box on the rear fender. When I put an implement on that doesn't need the top link (like a post hole digger), I store the top link in the tool box, or even bungee it to the ROPS vertically with hoses and all still attached.
/ Another CCM Hydraulic Top Link #17
Just watch the fittings/hoses clearance/orientation, those hoses are stiff and cannot come in contact with anything close to the cylinder or you'll end up with what happened to me. First time I lifted the 3 point the hoses made contact with the PBY frame and bent the hard lines so bad they leaked.
Felt like a real bozo :(
Doesn't seem to be any best way to install, some put the hoses down, some up, some out the side etc. I changed the position of the valve and turned to the side a little, for the length of my hoses this has worked out best for me.
Good luck, JB
Hi Steve,
Hope to install it Saturday morning. I did pick up a length of rod this morning so I hope to make a new TL holder as well.
Good luck, JB
Thanks for the tips JB. Steve
/ Another CCM Hydraulic Top Link #20
I got mine installed a couple weeks ago, but just got around to taking pictures yesterday. I ordered the 36" hoses so I could turn the check valve to the side.
I ordered it on the 17th of Feb, they shipped on the 18th, and I got it on the 19th. I installed it on the 20th. Now that is service!!!
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
Wooden Glider Chair (A64557)
Wooden Glider...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2022 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2022 KENWORTH T680...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
