Joe44
/ Joe44 #1
Joe44
Maryland
Kubota B7500
I have a Kubota B7500 with a front mounted snow blower. When I went to engage the front PTO, there was some grinding of the gears. The POT shift lever went forward but the PTO did not engage. The rear PTO is engaged at 540 rpm and will not disengage. The lever moves to both the forward and back positions without depressing the clutch.
/ Joe44 #2
Do you use the clutch when shifting the PTO????
/ Joe44
Yes but I sometimes disengage without the clutch.
/ Joe44 #4
Check the linkage for problems. One should use the clutch when shifting plain gears to avoid the grinding.
1995 Fontaine (A64911)
1996 John Deere 643D Feller Buncher Cut Down Machine (A66734)
1996 John Deere...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
2002 Harmon Steel Barrel 7,000 Gallon Asphalt T/A Tanker Trailer (A68183)
2002 Harmon Steel...
2002 PETERBILT 330 VACUUM BOBTAIL (A67714)
2002 PETERBILT 330...
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
