Joe44
   / Joe44 #1
Joe44
Maryland
Kubota B7500
I have a Kubota B7500 with a front mounted snow blower. When I went to engage the front PTO, there was some grinding of the gears. The POT shift lever went forward but the PTO did not engage. The rear PTO is engaged at 540 rpm and will not disengage. The lever moves to both the forward and back positions without depressing the clutch.
   / Joe44 #2
Do you use the clutch when shifting the PTO????
   / Joe44
Yes but I sometimes disengage without the clutch.
   / Joe44 #4
Check the linkage for problems. One should use the clutch when shifting plain gears to avoid the grinding.
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
