Can I trailer this tractor
/ Can I trailer this tractor #21
I 2nd the worry on the diamond plate, most trailers I have seen have angle iron "slats" so you are driving on the ^^^^^^^^^^^ instead of on the diamond plate _____
You might try hand sprinkling sand onto the wet paint? I dont know how long it would last.
/ Can I trailer this tractor #22
You can also weld some expanded metal over the diamond plate. I have seen this used on other trailers and it seems to work well.
/ Can I trailer this tractor #23
Seems like that would just hold dirt and snow.
Chris
/ Can I trailer this tractor #24
what is this snow stuff? that you are refering too? LOL us Florida boys know not of what you speak!
/ Can I trailer this tractor #25
I was thinking about your trailer and the cheapest most effective way I can think of to add a non slip other than paint on a non skid paint is to weld 1/2" Rebarb every 5" or so across the metal tail. It will not hold dirt and will give you plenty of grip.
Chris
/ Can I trailer this tractor #26
Nice trailer...I dont think your overweight at all.In fact your setup should tow perfectly....your only overweight by the GM trailer rating which is low,and for warranty only.It is not DOT enforceable,you are fine,enjoy your setup.
/ Can I trailer this tractor #27
It seems that you and I are the only ones that know this. :confused:
/ Can I trailer this tractor #28
What do you suppose his insurance company would say/do if he has an accident? I'd bet they'd be lookin' at the stage door left....
Good luck with that!
AKfish
/ Can I trailer this tractor #29
I went ahead and got a Gooseneck. It is a 8' x 20'+4' dovetail with two 7k axles with brakes. I bought it used, it is a 2005 (year) model and made by Black Brothers....never heard of them but the trailer seems to be made nicely. I was really impressed how well the trailer pulled behind my 3/4 ton Chevy and was alot more stable then a 10k bumper pull that I borrowed. I know I'm overweight with this trailer, like Diamondpilot said, " this trailer is half my tow rating," but the 6.0 gaser didn't strain to much and there isn't any mountains here and now I have a bigger trailer for when I upgrade my truck. Thanks for everyones input............Mike
Very nice set up. Goose neck pulls great, really the only way to go.
/ Can I trailer this tractor #30
mlitt,
The GM trucks can be a little confusing. You could have 3 trucks with three very different rear axles, all bearing the "2500" designation in 2003. I believe 2003 was the last year GM had the option of the regular 2500.
The regular 2500 has the same drivetrain as all of the 2500s did dating back to 1988 (disregarding the minor changes in the chassis). They have a 8600 lb GVWR, 8.825 " ring gear front axle and 14 bolt semi floating rear (9.25" ring gear I think). Spring ratings were similar.
The 2500HD's with 6.0L gas engines have a GVWR of 9200 lbs, have a larger front axle (don't know the size) and have the bullet proof 14 bolt full floating rear axle (10.5 " ring gear). An interesting note is that the newer 14 bolt FF's do not have the pinion gear snout bearing like the old axles had. Gears are not interchangeable, even though they look identical. Spring rates front and back vary by package, but are generally stiffer than the regular 2500.
The 2500HD with the Duramax diesel or 8.1L gas engines are the same as the 2500HDs with the 6.0L gas engines, except the transmission options (which have been beaten to death in many other threads and other forums) and the rear axle. The rear axle for these was designed and manufactures by AAM, is a full floating type with a 11.5" ring gear.
Add to that, the various suspension packages, like the towing package, snow plow prep, etc and you have a lot of variables in the exact towing and payload numbers. When you have trucks at the opposite ends of the "2500" spectrum, its not unreasonable to see the huge difference in payload and towing numbers.
Thanks for the replies.....my 2500 pulls the gooseneck fine (horrible fuel economy though) with just the tractor. If I put a couple of heavy implements on there also, it makes my 6.0L feel like a V-6.....so I'm going to upgrade to a diesel truck with higher towing capacity for peace of mind and safety.........Mike
/ Can I trailer this tractor #32
On top of all that many states require a class 'C' licence to tow above 10000lbs. You need to check on that also.
/ Can I trailer this tractor #34
Class C in California is not what you need you are in Oregon. According to DOT regs to tow over 10,000 lbs gross you need a commercial license. I know I know we all violate that one. The only exception that I am aware of is with the transport of recreational vehicles. The RV'ers have some great lobbyists. :)
/ Can I trailer this tractor #35
I know of no state other than CA that requires a CDL just because the trailer is over 10k.
/ Can I trailer this tractor #36
I agree, Texas is 26000#. I've go basically the same trailer. Bought it last year. I use it to haul just about anything. My tow rig is a 2004 Chevy 2500HD with the 6.0L gas. I've had so far 8 1200 - 1500 lb bales of hay as the heaviest load and my truck pulls if fine and haven't had any problems stopping either. Later this year I'll be moving my non-operational RV on it which weighs in about 9500lbs. Good trailer and you'll get a lot of good uses from it.
Enjoy.
/ Can I trailer this tractor #37
FWIW, To reduce the skid potential for the diamondplate on the end of the trailer you could try 3M's hd roll of adhesive with grit embedded in it. It is available in roll form, cheaper then just buying strips of it. It might work if the surface is real clean. You could try contact cement to possibly have better adhesion too. You can probably find it special order in most hardware stores or online.
Good luck.
Here's a link to an ebay seller's supply,(NO connection to me whatsoever!)
http://cgi.ebay.com/ws/eBayISAPI.dl...fffb05c&itemid=370314639083&ff4=263602_263622
Its 26k here in Alabama also for CDL..... I'm towing around 12k weight with tractor, implements, gooseneck trailer, chains etc. It pulls fine, stops fine, but with the 6.0L take offs are slow and fuel economy is terrible. I'm leaning towards rebar for anti skid on my dove tail also....looks like the cheapest easiest option...Thanks for the replies....Mike
/ Can I trailer this tractor #39
Make sure when you look at that Diesel Truck you do your homework. I see quite a few that will tow not much more than your 6.0 I like the Ford SRW F-350 with the Diesel but you must be careful because with the 4 different gearing options, bed lengths, cab options, and 8 or so suspension packages its tow rating can vary 5,000# or so. What I am saying is just because it says F-350 or what ever on the side does not mean squat.
Do your homework!
Chris
Thanks Diamondpilot, just like my Chevy 2500.....there is quite a few different tow capacities... From now on I will take a peak at that driver side door sticker......Mike
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
