Tires Front tires tow in/out and how much?
/ Front tires tow in/out and how much? #11
I have a 1955 Massey Harris Pacer (one of the first Compacts??) that had a lot of play in the steering box. Front wobble when you hit a bump at any speed on a gravel lane was scary. Before I repaired the box, I checked the toe-in, it was toed out quite a bit. Cranked it in some & wobble went away. Made a new hardened pin for the steering box & eliminated most all the play.
/ Front tires tow in/out and how much? #12
Actually it will probably leave the turn angle of the outside wheel unchanged because only one turn stop acts at a time and they are usually in front of the axle thereby stopping the angle of the outside wheel.
Since tractors are almost never going straight I dont see why even slight toe out would not be generally helpful.
larry
Toe in/out has nothing to so with the stops... It is the leading edge/lagging edge relationship of one wheel to the other...
Positive camber angle on the inside wheel in a turn could be helpfull, BUT on most tractors castor and camber are not something that can be changed... (most tractors do not have independent suspension).
My tractors spend most of their time going straight.
Set some toe out an give it a try, you will dial it back to toe in... toe out will tear up your lawn. KennyV
/ Front tires tow in/out and how much? #13
larry
For starters, a tractor with toe out will wander something fierce on hard surfaces at higher speeds. Just what you want on a public highway. Find me a tractor op manual that specifies toe out; I'll be the most surprised member of TBN.
/ Front tires tow in/out and how much? #14
Larry ... How do you figure that???
[It would be LESS for the other front tire...]
You always want toe in... even on a lil red wagon.
[Toe in/out has nothing to so with the stops...] It is the leading edge/lagging edge relationship of one wheel to the other...
[Then why in the world did you bring it up?]
Like I said, toe out in a turn is designed into the steering geometry. A little more seems needed on the 7520.
Why would = amounts of either toe out or toe in make any difference in tearing up the lawn? When going straight scrubbing would be =. Toe out would definitely tear it up less in tight turns.
larry
/ Front tires tow in/out and how much? #15
Understood. That is because neutral toe would develop as it went off straight, so the tractor would want to be turning....Back and forth. :)
larry
/ Front tires tow in/out and how much? #16
I'm with the 1/8" toe in crowd! ~Scotty
/ Front tires tow in/out and how much? #17
Just food for thought. It's not a tractor as such, but Honda recommends toe out for their Foreman ATVs. A fair amount too, as I recall, something like 8-12 mm from front to back of front tires.
Chilly
/ Front tires tow in/out and how much? #19
..(Post#3) .. Thanks,
This is an older farm tractor, and there is some play in the steering. When I go down the highway the front wheels want to wobble back and forth sometimes, so I thought a little tow might reduce this some. Any other suggestions other than changing my toe?
I "brought it up" in response to the #3post... as wonder and steering wobble will decrease as you increase toe in.
"It would be LESS for the other front tire..." - - is in response to post #3 ??! I dont understand how you are applying that statement then... and even less why you put it in a post answering me.
larry
/ Front tires tow in/out and how much? #20
larry.. Relax, I am not sure now what you are in reference to, or if you feel offended by my 'toe in is good, toe out is bad' position.
The OP asked about the amount of toe in, the 3rd post (from the same fella) mentioned why he asked, and that there was looseness in his steering that allowed "wobble back and forth sometimes, so I thought a little tow might reduce this some." I agreed with that in #5 and added another possable cause of front end wobble... out of round tires.
Your #7 ..."Just a thot, but wouldnt toe out be better for turning on a tractor? That way the tire on the inside of the turn would be turned sharper.
larry"
My response to you ... was that I couldn't see how you figured that as the outside wheel would then be turning at a LESS angle...
My only reason for bringing up toe in at all was to answer the question about .... toe in.... !
If you have taken this as some type of attack... It certainly was not intended as such... I simply stated try your theory of toe out, see what it does. And that I thought you would soon be setting it back towards toe in as I can see a lot of damage to your lawn using toe out to assist in a turn...
Try it you might have came up with a great turning assist? KennyV
PS. Anyway I do hope the OP has found the correct setting for his tractor....
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
2018 John Deere Z997R (A53317)
2018 John Deere...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2005 All Pro L7077 (A60462)
2005 All Pro L7077...
