never thought of a chain to limit height. Do you make the chain so short that the 3pth can not go all the way up? Would this cause damage if you moved the 3pth lift lever all the way back? I could see this chain being needed while dumping my trailer, Thanks, Greg
You can set the chain for what ever max height you want, if you are worried about bending your draw bar by lifting against it you could raise the 3 pt all the way up and hook chain there, so it couldn't go any higher.
I hook mine so it can only go maybe 3/4 of it's full travel, if pulling a trailer I don't need it any higher. You can feel the resistance if you pull against it, nothings just gonna snap but you could bend the draw bar by lifting 3 pt if you wanted and the bar was in the outer most position.
But under normal use like trailer tongue rising/bouncing, you wouldn't bend anything.
I see your trailer is quite large, alot longer looking than mine and your axles are farther back than mine also, so maybe yours doesn't come up at the hitch when you dump it? Mine does (forcefully) that's why I said you'd need it for dumping, but for yours maybe not?
I use mine all around the yard, even down steep driveway, I haven't had a problem. But your trailer looks bigger so a couple of things you can do to make pulling it safer, besides the limit chain, if you have 4x4 that would give some engine braking to the front wheels. But if you were really worried about going down a steep hill with a load, then if your trailer has an on board battery break away braking system you could tie a line to that pull out switch and hold on to it in a hairy situation, and if needed you could pull the break away pin for an emergency stop.
You'd have your hands full trying to get out of that predicament once employed, but at least it would bring things to a halt at the moment.
JB.
